11-05-2017 03:53 PM - last edited on 03-06-2024 09:09 PM by ROGBot
11-05-2017 05:53 PM
11-05-2017 06:04 PM
abluejelly wrote:
Where's the setting for that?
11-05-2017 06:24 PM
JustinThyme wrote:
This is a LAN connection (on my desktop ATM) so it doesn't show the bands but this is where you will find it.
Right click on the wireless symbol in the taskbar>open network & internet settings> change adapter options>right click on the adapter you wish to check (should be Intel AC 8260)>select properties> then advanced tab.
Another thing is to make sure you have the latest intel proset drivers (do this first), not whats on ASUS website. I always grab the software and driver package and make sure you get the BT while you are at it. Download the new ones then uninstall the old ones, reboot, intall the new ones, reboot.
https://downloadcenter.intel.com/product/86068/Intel-Dual-Band-Wireless-AC-8260
11-06-2017 08:33 AM
11-07-2017 03:02 PM
Clintlgm wrote:
your problem is not a common problem with the G752VY modles. Mine works fine. I did have issues with the FCU, and ended up doing a clean install with the FCU install media created by MCT
11-07-2017 04:02 PM
03-16-2018 09:39 AM
Darnassus wrote:
It's just a spam / phisher.
But damn, this all helps with my wifi dropping problem..
Thanks for the bump, bot.
