Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
  1. #11
    ROG Member Array
    May 2011
    21
    Making sure someone saw this. Any help would be appreciated.
    Thank you,
  2. #12
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    318
    7,887
    That GPU is probably the biggest thing holding you back if you are using GPU rendering. Yes a new GPU will be bottlenecked by your CPU but you will be able to take it with you when you update to a new platform. A motherboard & CPU update would be a nice quality of life upgrade and would help with CPU rendering. Of course that would be more money to replace motherboard, CPU, CPU cooler, and memory. One option is always to look at the used market near you. Sometimes there are folks updating from something that's only a generation or two old. If you are limited on funds that might be a way to get more stuff upgraded for the same dollars.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
  3. #13
    ROG Guru: Orange Belt Array Super Gnome PC Specs
    MotherboardROG Rampage VI Extreme Omega / ROG Crosshair VIII Formula
    ProcessorIntel® Core™ i9-9980XE / AMD 3950x
    Memory (part number)Corsair LPX Vengeance DDR4 2666MHz 128 GB / Corsair Vengeance LPX 32GB DDR4-3200 32GB DDR4 3200MH
    Graphics Card #1Asus 2080 Turbo / Asus 2080 ti Turbo
    Graphics Card #2Asus 2080 Turbo / Asus 2080 ti Turbo
    MonitorJAPANNEXT JN-VT500UHD 4K 50-inch LCD
    Storage #1Crucial MX500 1 TB / Sabient SB-ROCKET-NVMe4-500
    Storage #2Samsung 970 Pro 1 TB / ADATA XPG SX5500 Pro 3D NAND NVMe Gen3x4 PCIe M.2
    CPU CoolerROG Ryujin 360 / NZXT Kraken X62
    CaseThermaltake View 71 TG / Thermaltake View 31
    Power SupplyCORSAIR AXi Series, AX1600i 1600 watt / Thermaltake Toughpower iRGB 1200 watt
    Accessory #1 Noctua 140mm 3000 RPM x 4 / Noctua 140 mm 3000 RPM x 2
    Accessory #2 Gigabyte GC-A 2WAY NVLINK RGB (3-slot) / ROG NVLINK Bridge 3-Slot A
    Mar 2019
    31
    409
    I have a three rigs I built myself. One has a Rampage III Black Edition motherboard, and as much as I complain about Asus, that motherboard is still great after all these years.
    Here is what I did to upgrade it. First I got a new hard drive--an SSD--that made a huge difference. Then I got a new GPU, and then two in SLI (switched from a gtx 580 to a 1070 and then to two 1070s in sli). I have switched out one set of cards for another--both do well in it (switching from two 1070s to two 2080s). That doesn't mean you need to run out and get two gpus, but I did--and the difference was real.
    As for building a new system, I built a system with a Rampage VI Extreme Omega (Intel) and just last week another with a Crosshair VIII Formula (AMD). The Rampage VI Extreme Omega was fine for nearly a year, but it crashes now when playing World of Warcraft--and since 8.3 was released under load. But the system is so beefy I still don't get what is going on--but the latest BIOS from Asus also causes the CPU to run overclocked at default settings. As for the Crosshair VIII Formula--building the system was a snap, and the installation of Windows went like a dream--that was not the case with the Rampage VI Extreme Omega. Installing Windows was a nightmare with that system and it had lots of problems with Windows--hence I had to play around with the registry because the system had one of the CPU cores running at 100 percent.
    Another thing I did (with the Rampage III Black Edition) was ditch Windows 7. Windows 7 was a nightmare, and some of the updates simply would not jive with the system (the Rampage III Black Edition). Sometimes I had to rollback the updates, other times they simply would not install. Other times there would be errors, etc. And my system too would take forever to start up, and needed to literally be left alone for ten minutes or it would not work properly if you did anything. The upgrade to Windows 10 was easy and the system now works perfectly (but you cannot install any Asus software once you do that--which, ironically is a GREAT thing). Yes, a GREAT thing (seeing as hardware is Asus's strong point--the software, frankly speaking, is often buggy and just plain poor).
    As for a CPU upgrade, my Rampage III Black Edition has a 990x--the best you could get a the time (a six core processor) and it, along with the motherboard, this CPU has stood the test of time. One thing though--I would not get an Asus AIO water cooler and would be sure to get one that responds to the CPU core temperatures vs the CPU socket temperatures. It would also be nice if Asus provided users with a way to monitor the coolant temperature like Kraken X62 does. I give the Kraken X62 software (Cam) five stars because it allows you to watch you coolant temperature (which HWMonitor does not). Asus software is often poor and is widely criticized (along with Asus after care) as reflected in the very poor ratings in the Microsoft store that Armory Crate gets. Never mind the regular complaints on this board about RGB management--which I have given up on and pulled hair out trying to get working well.
  4. #14
    ROG Member Array
    May 2011
    21
    Thank you both! Looks like I have some research to do for my next step.
Tags for this Thread
