11-05-2017 08:09 PM - last edited on 03-05-2024 09:47 PM by ROGBot
11-06-2017 12:10 AM
Rippin Kittin wrote:
Hi, I have my i7-4790K OC'ed at 4,5GHz both core and cache.
Core voltage set to: 1.270
Core cache set to: 1.250
Initial CPU input voltage at: 1.990
Eventual CPU input voltage at 1.990
Does it look good, or am I doing something wrong?
11-06-2017 05:36 AM
tommiboi wrote:
Am guessing you are talking about the the voltage for your motherboard.
more info required from you.
Like what test you did and what heat you are at ect. Check some guides on YOU TUBE. If something is not clear after that. You can ask more specific questions.
GL HF on your OC !
11-07-2017 12:40 PM
11-08-2017 06:53 AM
UPDATE #2... (about my 4,5 GHz OC)
There's no one speaking in here. I just made a few more changes...
I've been stresstesting my i7-4790K for 20 hours now without a crash and I'm running CPU cores @ 100%
Temperature: 88C (full load)
Temperature: 32-35 (idle)
Cores: 45 @ 1.290
Core caches: 45 @ 1.270
Initial CPU input voltage: 1.2060
Eventual CPU input coltage: 1.2060
Reson I'd like some feedback is that I know some people might think my Initial and Eventual
voltage might look very high, but the fact is, my system will crash if I'm around the 1.9's!
11-08-2017 12:42 PM
ThrashZone wrote:
Have you run realbench ?
Post the results
https://rog.asus.com/tag/realbench/
Also post a link to your cpuid validate score too
11-08-2017 12:52 PM
ThrashZone wrote:
Post the results
11-10-2017 09:28 PM
Aye, aye - here comes the CPU validation file:
https://valid.x86.fr/szbx4c
