Results 1 to 10 of 10
    New ROGer Array
    Nov 2017
    1
    Strix SOAR many issues
    Hello everyone,
    To give some quick background I have had my Strix SOAR card since 2016. It worked perfectly fine with Sonic Studio II software till about a few months ago.
    The problems I am having is that when I boot windows I just see a red "x" over my speaker icon for a while. Then after about 5-10mins my speakers work fine again and I hear the "click" from my soundcard that it recognizes them.
    I have tried multiple drivers aka Sonic Studio versions since you have to d/l the whole package. I have even tried using multiple ASMedia drivers as I heard something about those causing issues for some.
    I have uninstalled/removed the card.
    To me it must be a combination of drivers and windows.. its the only thing I can figure out. When I contacted ASUS support I was not given much help. First they asked me to do all the things I have already done. Then the directed me to the QVL for my Motherboard (which is a Maximus Hero ASUS board by the way) to tell me that it is not on the list. So it "may" not work properly with my board. If that was the case it wouldn't have worked for almost 1 year before I had issues.
    At this point I'm ready to pull it out and go back to my SoundblasterZ to see if updated drivers are now working better (which is why I replaced that card).
    For my specs:
    Windows 10 Pro (latest updates)
    Maximus IX Hero mobo w/7700k cpu @4500 but not o/c
    16gb ddr4 3200 ram
    Geforce 1070
    750w EVGA PSU
    ASUS ROG GSYNC Monitor
    Acer monitor as 2nd
    I included the monitors since they have sound as well just in case I missed something.
    I'm guessing I won't get much help from ASUS but maybe someone out there is having similar issues?
    **also these issues have been before the Fall Creators Update in case anyone wonders.
    ROG Junior Member Array
    Nov 2017
    3
    Exclamation
    Quote Originally Posted by rsciba23 View Post
    Hello everyone,
    For my specs:
    16gb ddr4 3200 ram
    Geforce 1070
    750w EVGA PSU
    Acer monitor as 2nd
    Hi there,
    I have the same issue. After Windows10 Fall Creators Update my Soar is not recognized after a cold boot. I'm using the latest driver 1.1.18 and tried it with the whql 1.1.13 already -> same issue. I also tried to restart the windows services after a cold boot (Windows Audio Service & AudioEndpointbuildert). Nothing worked for me. I also checked Bios Settings...
    I only can fix the problem with restarting my PC after a cold boot with a warm boot but i have to wait for 1 mins after cold booting.
    My specs are:
    Windows 10 Home 64 bit on a Samsung 830 SSD
    MSI Z170A M5 w/ 6800k cpu oc'ed
    16gb G.e.I.L. DDR4 3000
    Aorus Geforce 1080ti extreme (no matter if NVIDIA Output is activated or deactivated)
    Enermax Platimax 600W PSU
    ASUS ROG PG348Q Monitor (no matter if sound is activated or deactivated)
    I've heard about to deinstall Fall Creators Update to fix the Problem but this is not an option for me atm.
    If someone has a solution to fix this please let us know
    Nov 2017
    3
    still have this issue... there is no update for win10 or soar driver
    New ROGer Array
    Aug 2017
    7
    Exclamation
    I have the same problem for a week with this card, someone found a solution to this problem?
    ROG Member Array exwound PC Specs
    exwound PC Specs
    MotherboardAsus B85M-E
    Processori5 4460
    Graphics Card #1Palit Jetstream 1060 6GB
    Sound CardAsus Strix Soar FW 1.03
    Power SupplyFSP ATX-500PNR
    exwound's Avatar
    Jan 2018
    15
    Do you tried to reinstall Asmedia drivers? Try to:
    1.Uninstall Sonic studio & Asmedia usb drivers
    2.Reboot
    3. Install latest Asmedia usb driver
    4. Reboot
    5. Install Sonic Studio
    6. Reboot
    New ROGer Array
    Aug 2017
    7
    Quote Originally Posted by exwound View Post
    2.Reboot
    4. Reboot
    6. Reboot
    I also tried this but it did not do anything, problem only appears when the computer is not run for hours
  7. #7
    New ROGer Array
    Aug 2017
    7
    Asus will finally fix the problems with this card or should I just pack this piece of electronic scrap into the box and give it back for guarantees ?, because I tested carte on clean w7 64bit and the problem is the more serious card now in the system does not detect at all, I can not even install drivers
  8. #8
    Nov 2017
    3
    Still same issue... i tried to install latest asmedia usb3.1 driver for windows10 64bit and tried to reinstall sonicstudio... its still the issues since windows 10 fall creators update.
  9. #9
    Administrator Array MasterC@ASUS's Avatar
    Aug 2014
    96
    1,492
    Quote Originally Posted by edeltraut2k View Post
    Try running your 6800k and everything else at stock. Reinstall Windows if necessary after reverting to stock speeds.
  10. #10
    Aug 2014
    96
    1,492
    Quote Originally Posted by SeBo1020 View Post
    Is your system overclocked?
    Have you tried different PCIe slots?
    Did you populate all/more slots recently?
