Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    ROG Guru: Yellow Belt Array
    Sep 2012
    177
    2-way SLI and 3x 960 Pro possible ?
    Hello,
    i want to know:
    can i use my 2-way SLI (gtx 1080ti) @16 PCI Lanes and three Samsung 960 Pro nvme at the same time?
    Or did the sli run only @8x ?
    CPU is 7980XE with 44 pci lanes.
    Thank you very much.
    ROG Enthusiast Array Georgia PC Specs
    Georgia PC Specs
    Laptop (Model)Microsoft New Surface Pro
    MotherboardASUS Rampage vi Extreme
    ProcessorI9 7900X
    Memory (part number)Corsair Dominator Plattinum 3466c16 128gb
    Graphics Card #1Asus Strix Gtx1080ti -oc
    Graphics Card #2Asus Strix Gtx1080ti -oc
    Sound CardOnboard
    MonitorAsus PG29Q-Dell U3011Ultrasharp-Dell U2713H
    Storage #13xSamsung 960 pro nvme 512GB
    Storage #2Intel ssd dc s3520-240Gb x 4 raid 0 / Intel ssd 730 x 2 raid 0
    CPU CoolerDual Custom Loop
    CaseCaselabes STH10 Fully Optioned
    Power Supply2 X Corsair Ax 1200i Titainium
    Keyboard Asus Rog Claymore
    Mouse Asus Rog Gladius 2
    Headset Astro-A40 Gen3 MixAmp TR pro
    Mouse Pad Asus Rog Sheath
    Headset/Speakers Audioengine B2
    OS Win 10 Professional x64
    Network RouterASUS Dsl AC-3100 ASUS RAPTURE AC5300
    Accessory #1 Cyberpower Ups
    Accessory #2 Saitek x55
    Accessory #3 Logitech g29
    Oct 2013
    73
    Hi i run 2-way sli (GTX 1080ti's) @ x16 with 3 Samsung pro nvme drives.
    1 in Mobo and the other 2 in the Dimm.2 adapter on the R6E.
    CPU is 7900x with 44 pci lanes.
    Hope this helps.
    Sep 2012
    177
    Great, thanks for the info!
    But the Samsungs will run at full speed?
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,857
    Quote Originally Posted by Mappi75 View Post
    Can you please post up full specs.
    My guess to your answer with limited knowledge is whether or not they run at full speed is a matter of precise what you are doing and how the 960s are assigned. You have 44 lanes to use but thats 44 lanes for everything. Keep in mind that with what you are proposing something will be sharing bandwidth at some point regardless of the configuration. Some lanes must feed the PCH.
    Post up your specs and more help can be offered into how your lanes will be allocated and what resources will be shared.
    Sep 2012
    177
    My system:
    Intel Core i9-7980XE @ Noctua NH-D15S | ASUS ROG Rampage VI Extreme | MSI GTX 1080 Ti Lightning Z SLI | G.Skill 128GB RAM, DDR4-3200, CL14 | Samsung SSD 960 PRO 2TB | 2x Samsung SSD 840 PRO (512GB) + 2x Samsung SSD 830 (512GB) | Plextor PX-L890SA | Corsair AX1500i Titanium | Lian Li TYR PC-X2000F @bequiet Silentwings USC |
    The question is:
    will the SLI and 3 Samsung 960 Pro work with full bandwidth (all @full speed) at all and the same time?
    ATM i only use one 960 pro ssd so i have to buy new ones (so i cant test it by my own).
    Dont want to raid them - only single drives only.
    Intel Core i7-6950X @ Noctua NH-D15S | Asus ROG Rampage V10 Extreme | MSI GTX 1080 Ti Lightning Z | Kingston 128GB RAM, DDR4-2666, CL15 | Seasonic 1.000 Platinum |
    ROG Guru: Yellow Belt Array CSN7's Avatar
    Sep 2013
    144
    Random question: Is one of your lightning Z from germany ?
  7. #7
    Sep 2012
    177
    Nobody knows the answer?
  8. #8
    ROG Guru: Yellow Belt Array Marko911 PC Specs
    Marko911 PC Specs
    MotherboardAsus Rampage extreme VI
    Processori9 7900x @4,7Ghz cores at from 7x1,20v-3x1,21v
    Memory (part number)G.skill 32GB 3200MHZ CL14 DDR4 quad kit
    Graphics Card #1Aorus 1080ti extreme edition @2032Mhz/12000Mhz
    MonitorAsus something IPS,144Hz ,Freesync
    Storage #1m.2 Samsung EVO 960 1TB
    Storage #2m.2 Samsung EVO 960 500GB
    CPU CoolerEKWB monoblock
    CaseThermaltake view 71 TG
    Power SupplyCorsair RM1000i
    Keyboard rappo wireless keyboard and mouse
    Headset Logitech G933
    OS win 10 pro/64bit
    Accessory #1 HL GTS 360mm/push only
    Accessory #2 HL SR2 360mm push/pull
    Accessory #3 HL SR2 420mm push/pull
    Marko911's Avatar
    Dec 2017
    141
    Hello,
    i want to know:
    First and thrid PCIe slot for GPUs in SLI=32 lanes,and than you have 8 more lanes for dimm.2 slot for 2 Nvme's ,and one needs to go on mobo m.2 that is routed trough PCH ,CPU gives PCH 4 lanes,so m.2 on mobo will not run as fast as the two m.2 on dimm.2 slots,because 4 lanes are shared.Hope this helps.
  9. #9
    ROG Guru: Orange Belt Array
    Oct 2017
    258
    Couple of questions are you running RAID or just 3 separate drives, second question are you running VROC, by Default the DIMM.2 runs VROC. If you are running separate drives and the DIMM.2 is running VROC you have no issues with bandwidth. 32xPCIe lanes with 2 GPUs 1st and third slots. The MB NVMe slot is running PCH that's x4. And the DIMM.2 is running x4. That's using the full 44 lanes. Now if you switch the DIMM.2 to PCH you have a bandwidth problem and especially if you also run RAID when doing that. No MB I know can have 3 NVMe drives on PCH in RAID and can handle the bandwidth requirements. You barely get any extra performance gain from the third drive. With all 3 drives on PCH, if you run three separate drives, you will never hit all three simultaneously normally so no bandwidth issues really. And lets get real most of your operations are at 4K random reads/writes low queue depth the slowest mode the drives operate in so no real issues any combination. Large file copies and such are the only real things that swallow large bandwidth.
  10. #10
    ROG Enthusiast Array birdman941 PC Specs
    birdman941 PC Specs
    MotherboardAsrock X299 Taichi XE
    Processori9 7900X (delidded)
    Memory (part number)64GB (4x16) Ballistix DDR4 2666 1.2V
    Graphics Card #1EVGA 1080ti SC2 hybrid
    Sound CardOnboard (Creative)
    MonitorLG - 27UD68 27" 4K
    Storage #14 x 280GB Intel Optane U.2 to M.2 in RAID0
    Storage #2Asus Hyper M.2 x 16 AIC
    CPU CoolerCorsair H115i 280mm push/pull
    CaseEnermax Ostrog GT blue
    Power SupplyCorsair HX 1000i w/Blue braided cable set
    Keyboard Corsair Strafe Cherry MX Red
    Mouse Corsair M65 PRO RGB
    Headset Turtle Beach Ear Force Stealth 450
    Mouse Pad Corsair MM300
    Headset/Speakers Creative SoundBlasterX Katana
    OS Win10 Pro OEM
    Accessory #1 Asrock Thunderbolt 3 AIC
    Accessory #2 Rockit Cool X299 delid tool
    Accessory #3 COUGAR Armor-S Gaming Chair
    Nov 2017
    53
    Doesn't X299 with i9 7900X and above have 44 PCIe lanes direct to CPU,
    and 24 through the PCH?
