Results 1 to 2 of 2
    New ROGer Array
    Nov 2017
    1
    why base standby voltage is too high?
    hello. i m using Z370F motherboard.
    and 0430 bios .
    i wonder why VCCIO and standby voltage is too high? (i m using G.SKILL XMP)
    1.35V VIO STB voltage is red value..
    so i set VCCIO 1.2 , Standby 1.2 is it ok?
    Tech Marketing Manager HQ Array Raja@ASUS's Avatar
    Apr 2011
    164
    7,453
    The auto voltages are set for worst case CPUs. If yours can run lower, it is okay to set manually.
