Aura RGB LED problem
bixsi
hello,
very annoying
what is the problem ?please help me,
I am using asus aura lighting control but an old version.
there was no such problem before
17 REPLIES 17
AkaNe0
bixsi wrote:
hello,
very annoying
Which version of AURA are you using? The latest one available is 1.05.25. Make sure to have the latest BIOS and drivers as well.
And don't forget, Keep pushing it !
I've updated Aura, but the problem continues.
I not updated my video card BIOS, Where can I find the current bios?
Thank you so much ?
Thank you so much ?
For the BIOS, it's for the motherboard. You can find them on the support site, by looking at your model name.
Sorry bro but Why am I updating the motherboard for RGB LEDs?
Is there a connection?
The bios version of the video card is old, I update it too ok ?
It can sometime impact the overall sync. Always better to have the latest BIOS and drivers.
Which motherboard do you have, and what is the model of your graphics card?
Yes, I understand.
graphic card: ASUS ROG STRIX GTX1080 A8G Gaming
motherboard: MSI Z170A Gaming M7
Graphic Card Bios version: 86.04.17.00.E3
bixsi wrote:
Yes, I understand.
As you have a MSI motherboard, you need to install the AURA RGB control for graphics card available under utilities on the support page of the GTX 1080 or direct link here.
Note that the regular AURA software, cannot work without an ASUS AURA sync motherboard.
Check the full list of AURA sync products.
OK for the BIOS of your graphics card.
I have updated the aura, but the problem persists:(
I will update the graphics card BIOS, I hope I can handle this error:(
otherwise I will send the card to the warranty service.
Thank you for your interest.
I have updated my bios, but the problem still persists.
Is this a card or LED fault??
Is it an aura software error???
