Strix z370-e pwr_led
PsyTech
I've looked around the BIOS to no avail. Does anyone know how to/if it's possible to Disable this super bright ORANGE LED? It is a massive eyesore in my new black and white build. I know it's a minor thing but still, I focused a lot on the aesthetics of this build and it is the one thing that's not quite perfect (okay not the only thing but the most obvious)
Raja
You can't disable it. I use some black electrical tape or cut some vinyl wrap to create a cover for anything I want to hide in a build. Works well.
Carbonicdk
There's a 3D print mounting hole nearby if you want to be super creative.
