Results 1 to 9 of 9
    New ROGer Array Amigo PC Specs
    Amigo PC Specs
    MotherboardAsus Maximus VIII Hero bios 3504
    ProcessorIntel i7-6700K
    Memory (part number)2x8Go Crucial DDR4-2400
    Graphics Card #1Radeon R9 200
    Sound CardCreative SB X-Fi
    Storage #1Samsung SSD 950 pro 512 Go
    OS Windows 10 64bits
    Nov 2017
    4
    Issue in my bios with a M2 Samsung 950 pro
    Hello
    I've mounted a watercooled PC with Windows 10 64 bits with an Asus motherboard Maximus VIII Hero, on a Samsung SSD M2 950 pro (see my profile for details).
    Everything works, but sometimes i have some bugs, and the performance of my SSD is very bad :
    http://hdelaubier.free.fr/Asus%20Hero%20viii%2003.png
    http://hdelaubier.free.fr/Asus%20Hero%20viii%2004.png
    http://hdelaubier.free.fr/Asus%20Hero%20viii%2005.jpg
    When i go to the bios (v.3504 or previous version), i see nowhere the option M.2 !
    http://hdelaubier.free.fr/Asus%20Hero%20viii%2001.jpg
    http://hdelaubier.free.fr/Asus%20Hero%20viii%2002.jpg
    I've done a search for several days (Google, french forum, etc.) and found Nothing :/
    I would be gratefull for your help
    Friendly,
    EDIT : some benchs with Cristal Disk
    http://hdelaubier.free.fr/crystal%20...0mark%2001.png
    http://hdelaubier.free.fr/crystal%20...0mark%2002.png
    http://hdelaubier.free.fr/crystal%20...0mark%2003.png
    Administrator Array Silent Scone@ASUS's Avatar
    Mar 2016
    124
    1,831
    Quote Originally Posted by Amigo View Post
    Hello
    Friendly,
    First off, is the drive running the latest firmware?
    Also if the system is overclocked, try at defaults - including no XMP profile.
    Amigo PC Specs
    Nov 2017
    4
    Hello,
    Yes i've got latest firmware for my 950pro
    http://hdelaubier.free.fr/Magician.png
    My CPU is not overclocked, XMP is desabled
    Mar 2016
    124
    1,831
    Any other expansion cards installed?
    Try using both PCIE4 and the M.2 socket.
    Amigo PC Specs
    Nov 2017
    4
    If i understood properly, no expansion card except my sound card Creative SB X-Fi, installed on the PCIe slot N1 :
    http://hdelaubier.free.fr/Layout.PNG
    And my video card radeon R9 200 ?
    Where should i try to install my SB X-Fi eslsewhere ? I've got a watercooling that makes any changes very difficult
    ROG Guru: Grand Master Array
    Oct 2012
    339
    15,255
    Are you using the M.2 slot or PCIe adapter for your M.2 SSD?
    Also can you do an AS SSD run for me?
  7. #7
    Amigo PC Specs
    Nov 2017
    4
    I use the M.2 slot.
    If i can't solve the issue, i will buy these kind of adapter
    https://fr.aliexpress.com/item/PCI-E...766479188.html
    But it will be difficult because of my watercooling system that is taking a huge place
    Is a cristal disk bench enough for you ?
    Plus a Cristal disk info :
    http://hdelaubier.free.fr/Cristal%20info.png
    Edit : BINGO !!!
    I just have updated my Windows 10 with the update 1709, and now everything works perfectly !
    http://hdelaubier.free.fr/Asus%20Her...2004%20bis.png
    http://hdelaubier.free.fr/Asus%20Her...ii%2004ter.png
    But guess what ? My sound card Creative SB X-Fi is desactivated, i don't hear any sound from my computer.
    So there is a link between my poor performance of my 950 pro and the PCIe slot used by my SB X-Fi !
    Thanks for having focus my attention on additionnal cards, if everything goes well when i will turn on the sound in a way or another, i won't come back here.
    Thanks again, i'm lucky because i was annoyed by this for half a year
    Wishing you all the best,
  8. #8
    ROG Guru: Brown Belt Array NemesisChild PC Specs
    MotherboardASUS Maximus X Hero (WI-FI AC)
    ProcessorIntel i7 8700K
    Memory (part number)G.Skill F4-3600C16D-16GTZR
    Graphics Card #1Nvidia GTX 1070 Ti FE
    Graphics Card #2Nvidia GTX 1070 Ti FE
    MonitorASUS ROG Swift PG278Q
    Storage #1Samsung 970 PRO 512GB NVMe M.2
    Storage #2WD Black 2TB 7200 RPM 64MB Cache
    CPU CoolerNZXT Kraken X42
    CaseCooler Master HAF 932 Advanced
    Power SupplyEVGA SuperNova 1200 P2
    Keyboard Logitech G910 Orion Spark
    Mouse Logitech G703 Wireless
    Headset Logitech G Pro
    Mouse Pad SteelSeries
    OS Windows 10 Home x64 (UEFI)
    Network RouterLinksys WRT1900AC
    NemesisChild's Avatar
    Sep 2011
    89
    1,788
    There is no M.2 option in the bios for this board, it automatically detects the drive.
    Intel i7 8700K@ 5.2GHz (Delidded)
    ASUS Maximus X Hero (Bios 1801)
    NZXT Kraken X42
    G.Skill TridentZ@ 4000MHz CL16 2x8GB
    SLI: 2x Nvidia GTX 1070 Ti FE@ 2025/2025MHz
    OS: Samsung 970 PRO 512GB NVMe M.2
    Storage: Samsung 960 EVO 500GB NVMe M.2
    Storage: 2x Samsung 850 EVO 500GB
    Storage: WD Black 7200 RPM 64MB Cache 2TB
  9. #9
    Mar 2016
    124
    1,831
    I use the M.2 slot.
    Edit : BINGO !!!
    But guess what ? My sound card Creative SB X-Fi is desactivated, i don't here any sound from my computer.
    Depending on the slot, bandwidth is shared. This is in the manual.
    Glad it helped
