Results 1 to 1 of 1
    ROG Junior Member Array
    Nov 2017
    2
    GL702VS Quality Issues
    I just bought a STRIX GL702VS and have to say that the quality is awful.
    I got one of these over a week ago and it rattled, upon inspection I found a screw inside the casing. The screen also had a degree of light bleed so I took it back to Currys and got a new one ordered. My replacement arrived today and the light bleed is worse, I honestly don't know if this is a good enough reason to ask for another replacement or just get a different brand without this issue.
    Honestly this is my first ASUS product and I have to say that for a £2000 laptop the quality should be exceptional especially for something that comes with ZERO accessories, I mean Inside the box there is literally just the laptop, power adapter and a couple of booklets for the warranty and quick start.
    On top of this the casing of the base doesn't line up properly making it hard to connect the power adapter and impossible to use the Thunderbolt port.
    Disgruntled
Tags for this Thread
