Results 1 to 1 of 1
11-22-2017 01:45 PM #1
Recommended maximum allowed speakers for direct attach to Asus Soar?
Can I connect a very small speaker directly to the Asus Soar audio card?
I'm clearly new to audio cards.
The audio card has a dedicated power cable connector (like the GPU) to be attached to the power supply. So is capable to push more than a traditional weak signal. My PC power supplay is 1100 W.
> What is the maximum allowed speaker I can apply directly to the audio card Asus Soar?
IN ORDER OF MILLIWATTS = Very little
> How much power do I have?
Very little
> Can I burn my card attaching a normal 100w speaker?
> Can I use for example a JBL Cinema 610 power 100W, Nominal Impedance 4 ohms or a JBL Northridge N24AWII
recommended 100W, 200 Watts max and 8 Ohms Nominal Impedance?
You need an synth amplifier to connect to the passive speakers or Powerade speakers
Thanks for your time and knowledge!Last edited by Alan M; 11-26-2017 at 01:34 AM.
