Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 37
    New ROGer Array
    Nov 2017
    2
    GL553VD - Driver Power State Failure while playing certain games
    For some reason, when I play two of my games I get a Driver Power State Failure, a BSOD.
    What is strange is that I do not get this at all when I play my other games or not gaming at all.
    Anyone know how to fix this?
    I've already contacted ASUS Support and they said it was a hardware issue, but I hope I can fix this without sending my laptop off.
    Dump files: https://1drv.ms/u/s!ApMe8kFEmIEUkSQaN-2YuflpRnHe
    ROG Guru: White Belt Array mmohamed2's Avatar
    Jul 2017
    97
    uninstall intel 630 driver using Display Driver Uninstaller then ,after reboot,download and install an old version like 11/11/2016 or older
    I get this problem after i updated the intel 630 driver to 2017 version, but after doing that , i rarly get "Driver Power State Failure"
    I hope that help!
    New ROGer Array
    Nov 2017
    2
    Can someone help me analyse the dump files from the 26th and tell me what I need to fix?
    https://1drv.ms/u/s!ApMe8kFEmIEUkTCRrUAAdPnwMxlS
    ROG Member Array
    Aug 2017
    11
    I have the same problem
    *I have the same problem, when I'm in a game and press "alt + tab" to change the window, when I return to the game the screen freezes for a long time, until I get "Power State Failure,"
    New ROGer Array
    Nov 2017
    1
    (sorry for my english)
    I had the same issue with newest drivers, after that I reinstalled my windows with the drivers from asus (intel+nvidia) , and the result is better, no blue screen but the premiere pro, photoshop and programs where is important the nvidia graphic card stops responding very often, every 30-60 minutes. I bought my laptop 1 week ago, so i am very sure, it s a driver or windows problem. I hope the situation will be resolved soon. I am very disappointed.
    update: here is my minidump files https://goo.gl/eBLqkM
    update2: Now i reinstalled the windows, but not the newest. I installed the 1703 version, and now everything working good up to now, no freezes, no blue screen, up to date nvidia driver.
    ROG Member Array alexzhin PC Specs
    alexzhin PC Specs
    Laptop (Model)ASUS ROG STRIX GL553VD
    MotherboardASUSTeK COMPUTER INC. GL553VD.304
    ProcessorIntel(R) Core(TM) i5-7300HQ CPU @ 2.50GHz (4 CPUs), ~2.5GHz
    Memory (part number)2 x SO-DIMM socket, 4096MB RAM
    Graphics Card #1Intel(R) HD Graphics 630
    Graphics Card #2NVIDIA GeForce GTX 1050 , with 4GB GDDR5 VRAM
    Sound CardRealtek High Definition Audio
    MonitorGeneric PnP Monitor, 1920 x 1080 (32 bit) (60Hz)
    Storage #11TB 5400RPM SSH
    Power SupplyPlug Type :ø5.5 (mm) Output : 19 V DC, 6.32 A, 120 W
    Keyboard Chicklet keyboard with isolated Num key,
    Mouse Pad ASUS Precision Touchpad
    OS Windows 10 Home Single Language 64-bit (10.0, Build 15063) (15063.rs2_release.170317-1834)
    Network RouterIntegrated 802.11b/g/n Integrated 802.11 AC
    Sep 2017
    8
    Also face the same problem after updated to version 1709, after roll back to the 1703, everything return to normal.
  7. #7
    ROG Member Array
    Dec 2017
    11
    Question
    Okay i see this is a mass problem.
    Anyone managed to get workaround in windows 1709 because rolling back to 1703 is not an option for me
    Usually i get BSOD when i alt-tab or close the game so mostly its connected to video card swaping or such.
  8. #8
    Apr 2017
    14
    90
    Is it common problem?
    Hi everyone! How many users encounter this problem? Should I roll back to 1703 or not?
  9. #9
    New ROGer Array
    Nov 2017
    1
    TL:DR > Definetly YES!
    Quote Originally Posted by Lord Obsidian View Post
    If you have the opportunitty to rol back just do, this is not just common, it's almost certain to happen once you update to 1709, and the more you try to fix the more side issues you find! I am running on a 1709 and I can tell you the performance is not optimal, i have BSOD with DRIVER_POWER_STATE_FAILURE while closing up some apps and games, and all my drivers are up to date, while a friend of mine who has this exact same model, bought from the exact same shop, is still running 1703 and has no problems of such nature. We've disabled his Windows updates for now until a solution is found!
    Lets keep this thread alive and running, and if you guys find a solution please share! It's quite clear that this is a Microsoft update related issue, but none of the hotfixes/definition updates released until now have solved it (I am running insider preview to check if anything to be released fixes this mess, with no luck until now!)
  10. #10
    Jul 2017
    97
    Guys did splendid open for you on 1709?
