11-27-2017 03:07 AM - last edited on 03-05-2024 09:42 PM by ROGBot
11-27-2017 10:32 AM
Larkspeed wrote:
I'm wondering if Asus make such a thing as an Aura Splitter.
The reason I ask is I own a Rampage V Edition 10 and it only has one Aura header on the board.
I want to install multiple RGB fans and at least 2 RGB Strips since I have a full tower case.
I don't want to use just straight Y splitters as it would probably end up overloading the Aura controller on the board.
What I would like if at all possible is a small box that can be hidden behind the backplate that would plug into the on board Aura header and then pass whatever that header outputs through to multiple headers which you can plug other devices into, preferably with molex or sata power to it so it doesn't overload the on board.
One Aura setting would then make everything plugged into the splitter the same.
If Asus make something like that can someone point me in the right direction, if not then they can take this as a product suggestion because i'm pretty sure there are a lot of people who would pay for something like this.
11-27-2017 11:14 AM
KeksimusMaximus wrote:
You can make one yourself from bunch of wires and connectors. This is how you should put it together:
https://i.imgur.com/cdPwE4n.png
No need to overpay for something so simple like a power splitter, just to have a "Asus Aura compatible" sticker on it.
11-27-2017 11:27 AM
Larkspeed wrote:
...certified compatible...
11-27-2017 11:44 AM
And that's why PC enthusiasts are getting ripped off on every step on even simplest electronic components... Soon "Gaming cable splitter"...
11-27-2017 12:23 PM
namoi wrote:
Just buy rgb splitters from aliexpress. Works great and cost nothing.
Sent from my XT1562 using Tapatalk
11-27-2017 12:31 PM
Larkspeed wrote:
I already said I don't want to use a bunch of splitters, 10 RGB fans and 2 RGB strips are liable to overload the header
