Issues with GT-AC5300. Checking Connection in map. And other issues
LdGallifreyan
I just bought a GT-AC5300.
Being a Gamer.. I had a choice this router or the RT-AC86U, (Suggested by RMerlin).
But ignored him unfortunately as I thought this router would be better suited. Boy wasn't I wrong!
More annoyed that this Router does not have Full Cone NAT.. Being a Gaming Router.. I would like the option of OPEN NAT on all my PCs and Consoles.. (Should be Standard Since it is a Gaming Router)!
I have issues since I bought it a few days ago, with WiFi dropping out, lag and Oddities in the GUI and the Map,
The Map is showing Checking Connection... Constantly.
GUI Bug I suspect, as it has on the dash board and on map the wan ip, and I can gain Internet access.
GUI issue with the bottom Left Corner.. till you actually zoom in on a browser it will be white washed.
I sue with the Asus Router App. When you test your connection in the app it does a Red X on my modem.
But it has done this with other Asus Routers, (RT-AC68U-RT-AC3200).
The WiFi drops. Is I suspect a firmware issue.
Now with the WTFast, it says Canada or USA. Why doesn't it have a UK option?
I had issues with it when I clicked on Reboot in the Router itself, on the GUI Reboot. I forced it to Reboot as I had issues and thought it would sort it out and it wouldn't turn back on so I had to unplug the router from the wall.
Also Getting in the system log: The ERR of the Paid App to do with QOS.
So, I want to know if there is a newer better firmware coming?
I have sent a lot of feedback to Asus with no reply.
Current firmware: 3.0.0.4.382.15984
Bought from Amazon UK, for £388 and am annoyed at it,
Substandard and Not-Fit-For-Purpose!!
This Router is a Joke to all Gamers, this Router should not have the word Gamer or ROG Logo on it.
Errors:
Nov 27 15:31:16 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Nov 27 15:56:21 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Nov 27 15:56:23 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Nov 27 15:56:27 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Nov 27 15:57:34 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Nov 27 15:57:45 kernel: ERR[set_app_info_qos_meta:3335] Failed to find app info entry (5-4-132)!
Nov 27 15:57:46 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Nov 27 15:57:47 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Nov 27 15:57:51 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Nov 27 15:57:53 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Nov 27 15:58:48 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Nov 27 16:00:05 kernel: br0: received packet on eth8 with own address as source address
Nov 27 16:00:17 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Nov 27 16:00:48 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
(P.S. GT-AC5300 Is not Protected Against KRACK)
(We will not see a update till Broadcom Pulls there finger out and patch it,
To address the KRACK issue, so ASUS won't be pulling a update out till this is fixed..)
5 REPLIES 5
DirtTrash78
I had similar issue and after I updated the firmware I never had an issue again. I guess its personal preference but with 6 iOS devices, an Apple TV 4k, and my system all pulling from the same connection...I never see network lag. Someone from ASUS really needs to get this taken care of for you. And we all know getting support from ASUS in these forums is impossible. Best of luck brother.
I game daily and stream daily, and imo this router has blown away my previous ASUS 3200 router.
-Semper Fi
Stay Low Move Fast Kill First Die Last...OOORAH!!!
JustinThyme
Yes, check firmware.
Just retired this router after running it since its inception day and only did so because I needed a 10GB SFP+ connection to my 10GBe switch.
Never had any issues and not a single drop out.
Mote logs but from the replacement GT-AC5300..
Seems to have more errors than the first one I got.
Very disappointed!
System Time
Fri, Dec 08 09:45:31 2017
* Daylight savings time is enabled in this time zone.
Uptime 0 days 15 hours 12 minute(s) 39 seconds
Remote Log Server
Apply
Dec 7 23:54:11 rc_service: httpd 826:notify_rc restart_wan_if 0
Dec 7 23:54:12 rc_service: udhcpc 32739:notify_rc start_firewall
Dec 7 23:54:12 miniupnpd[32143]: add_filter_rule() : chain FUPNP not found
Dec 7 23:54:12 miniupnpd[32143]: Failed to redirect 3074 -> 192.168.1.110:3074 protocol UDP
Dec 7 23:54:12 miniupnpd[32143]: shutting down MiniUPnPd
Dec 7 23:54:12 wan: finish adding multi routes
Dec 7 23:54:12 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
Dec 7 23:54:12 rc_service: udhcpc 32739:notify_rc stop_upnp
Dec 7 23:54:12 rc_service: waitting "start_firewall" via udhcpc ...
Dec 7 23:54:12 miniupnpd[311]: version 1.9 started
Dec 7 23:54:12 miniupnpd[311]: HTTP listening on port 59550
Dec 7 23:54:12 miniupnpd[311]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 7 23:54:13 rc_service: udhcpc 32739:notify_rc start_upnp
Dec 7 23:54:13 rc_service: waitting "stop_upnp" via udhcpc ...
Dec 7 23:54:13 miniupnpd[311]: shutting down MiniUPnPd
Dec 7 23:54:14 miniupnpd[313]: version 1.9 started
Dec 7 23:54:14 miniupnpd[313]: HTTP listening on port 38752
Dec 7 23:54:14 miniupnpd[313]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 7 23:54:21 rc_service: udhcpc 32739:notify_rc start_firewall
Dec 7 23:54:21 dhcp client: bound **.**.***.*** via **.**.***.* during 409852 seconds.
Dec 7 23:54:21 miniupnpd[313]: shutting down MiniUPnPd
Dec 7 23:54:21 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
Dec 7 23:54:21 miniupnpd[1121]: version 1.9 started
Dec 7 23:54:21 miniupnpd[1121]: HTTP listening on port 33291
Dec 7 23:54:21 miniupnpd[1121]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 8 00:07:35 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 00:12:48 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 00:37:35 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 00:42:50 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 01:07:35 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 01:12:52 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 01:28:32 kernel: ERR[set_app_info_qos_meta:3335] Failed to find app info entry (4-4-193)!
Dec 8 01:28:32 kernel: pgd = ffffffc0326b5000
Dec 8 01:28:32 kernel: [6c6c6554] *pgd=0000000000000000, *pud=0000000000000000
Dec 8 01:28:32 kernel: CPU: 3 PID: 21357 Comm: nt_center Tainted: P O 4.1.27 #4
Dec 8 01:28:32 kernel: Hardware name: Broadcom-v8A (DT)
Dec 8 01:28:32 kernel: task: ffffffc0341de100 ti: ffffffc025fb4000 task.ti: ffffffc025fb4000
Dec 8 01:28:33 kernel: PC is at 0xf70b29d4
Dec 8 01:28:33 kernel: LR is at 0xf72eeccc
Dec 8 01:28:33 kernel: pc : [<00000000f70b29d4>] lr : [<00000000f72eeccc>] pstate: 400f0010
Dec 8 01:28:33 kernel: sp : 00000000f66fcaa0
Dec 8 01:28:33 kernel: x12: 0000000000000100
Dec 8 01:28:33 kernel: x11: 00000000f5d17e48 x10: 000000006c6c6548
Dec 8 01:28:33 kernel: x9 : 0000000000000000 x8 : 00000000f5df77e8
Dec 8 01:28:33 kernel: x7 : 0000000000000090 x6 : 00000000f5d00010
Dec 8 01:28:33 kernel: x5 : 00000000000022a8 x4 : 00000000f5df5540
Dec 8 01:28:33 kernel: x3 : 00000000674e206f x2 : 00000000f5df5540
Dec 8 01:28:33 kernel: x1 : 0000000000000000 x0 : 00000000f5d00010
Dec 8 01:30:42 kernel: pgd = ffffffc03026d000
Dec 8 01:30:42 kernel: [6c6c6554] *pgd=0000000000000000, *pud=0000000000000000
Dec 8 01:30:42 kernel: CPU: 0 PID: 21827 Comm: nt_center Tainted: P O 4.1.27 #4
Dec 8 01:30:42 kernel: Hardware name: Broadcom-v8A (DT)
Dec 8 01:30:42 kernel: task: ffffffc034242080 ti: ffffffc027090000 task.ti: ffffffc027090000
Dec 8 01:30:42 kernel: PC is at 0xf6e789d4
Dec 8 01:30:42 kernel: LR is at 0xf70b4ccc
Dec 8 01:30:42 kernel: pc : [<00000000f6e789d4>] lr : [<00000000f70b4ccc>] pstate: 400e0010
Dec 8 01:30:42 kernel: sp : 00000000f63fcaa0
Dec 8 01:30:42 kernel: x12: 0000000000000100
Dec 8 01:30:42 kernel: x11: 00000000f5a17e48 x10: 000000006c6c6548
Dec 8 01:30:42 kernel: x9 : 0000000000000000 x8 : 00000000f5af7160
Dec 8 01:30:42 kernel: x7 : 0000000000000090 x6 : 00000000f5a00010
Dec 8 01:30:42 kernel: x5 : 0000000000000298 x4 : 00000000f5af6ec8
Dec 8 01:30:42 kernel: x3 : 00000000674e206f x2 : 00000000f5af9708
Dec 8 01:30:42 kernel: x1 : 0000000000000000 x0 : 00000000f5a00010
Dec 8 01:31:46 kernel: pgd = ffffffc025cff000
Dec 8 01:31:46 kernel: [6c6c6554] *pgd=0000000000000000, *pud=0000000000000000
Dec 8 01:31:46 kernel: CPU: 0 PID: 22048 Comm: nt_center Tainted: P O 4.1.27 #4
Dec 8 01:31:46 kernel: Hardware name: Broadcom-v8A (DT)
Dec 8 01:31:46 kernel: task: ffffffc02a9c6b40 ti: ffffffc025fb4000 task.ti: ffffffc025fb4000
Dec 8 01:31:46 kernel: PC is at 0xf6f979d4
Dec 8 01:31:46 kernel: LR is at 0xf71d3ccc
Dec 8 01:31:46 kernel: pc : [<00000000f6f979d4>] lr : [<00000000f71d3ccc>] pstate: 400e0010
Dec 8 01:31:46 kernel: sp : 00000000f65fcaa0
Dec 8 01:31:46 kernel: x12: 0000000000000100
Dec 8 01:31:46 kernel: x11: 00000000f5c17e48 x10: 000000006c6c6548
Dec 8 01:31:46 kernel: x9 : 0000000000000000 x8 : 00000000f5cf7160
Dec 8 01:31:46 kernel: x7 : 0000000000000090 x6 : 00000000f5c00010
Dec 8 01:31:46 kernel: x5 : 0000000000000298 x4 : 00000000f5cf6ec8
Dec 8 01:31:46 kernel: x3 : 00000000674e206f x2 : 00000000f5cf9708
Dec 8 01:31:46 kernel: x1 : 0000000000000000 x0 : 00000000f5c00010
Dec 8 01:33:48 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 01:37:35 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 01:39:37 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 01:42:53 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 02:07:35 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 02:12:55 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 02:37:35 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 02:42:56 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 03:07:35 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 03:12:58 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 03:37:35 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 03:42:59 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 03:52:53 kernel: pgd = ffffffc0296e0000
Dec 8 03:52:53 kernel: [6c6c6554] *pgd=0000000000000000, *pud=0000000000000000
Dec 8 03:52:53 kernel: CPU: 0 PID: 17445 Comm: nt_center Tainted: P O 4.1.27 #4
Dec 8 03:52:53 kernel: Hardware name: Broadcom-v8A (DT)
Dec 8 03:52:53 kernel: task: ffffffc029475540 ti: ffffffc025c0c000 task.ti: ffffffc025c0c000
Dec 8 03:52:53 kernel: PC is at 0xf716b9d4
Dec 8 03:52:53 kernel: LR is at 0xf73a7ccc
Dec 8 03:52:53 kernel: pc : [<00000000f716b9d4>] lr : [<00000000f73a7ccc>] pstate: 400f0010
Dec 8 03:52:53 kernel: sp : 00000000f66fcaa0
Dec 8 03:52:53 kernel: x12: 0000000000000100
Dec 8 03:52:53 kernel: x11: 00000000f5d17e48 x10: 000000006c6c6548
Dec 8 03:52:53 kernel: x9 : 0000000000000000 x8 : 00000000f5df75a0
Dec 8 03:52:53 kernel: x7 : 0000000000000090 x6 : 00000000f5d00010
Dec 8 03:52:53 kernel: x5 : 00000000000022a8 x4 : 00000000f5df52f8
Dec 8 03:52:53 kernel: x3 : 00000000674e206f x2 : 00000000f5df52f8
Dec 8 03:52:53 kernel: x1 : 0000000000000000 x0 : 00000000f5d00010
Dec 8 03:54:53 kernel: ERR[set_app_info_qos_meta:3335] Failed to find app info entry (4-4-193)!
Dec 8 03:57:41 kernel: pgd = ffffffc0296e0000
Dec 8 03:57:41 kernel: [6c6c6554] *pgd=0000000000000000, *pud=0000000000000000
Dec 8 03:57:41 kernel: CPU: 0 PID: 18314 Comm: nt_center Tainted: P O 4.1.27 #4
Dec 8 03:57:41 kernel: Hardware name: Broadcom-v8A (DT)
Dec 8 03:57:41 kernel: task: ffffffc034243480 ti: ffffffc025fbc000 task.ti: ffffffc025fbc000
Dec 8 03:57:41 kernel: PC is at 0xf71749d4
Dec 8 03:57:41 kernel: LR is at 0xf73b0ccc
Dec 8 03:57:41 kernel: pc : [<00000000f71749d4>] lr : [<00000000f73b0ccc>] pstate: 400f0010
Dec 8 03:57:41 kernel: sp : 00000000f66fcaa0
Dec 8 03:57:41 kernel: x12: 0000000000000100
Dec 8 03:57:41 kernel: x11: 00000000f5d17e48 x10: 000000006c6c6548
Dec 8 03:57:41 kernel: x9 : 0000000000000000 x8 : 00000000f5df7410
Dec 8 03:57:41 kernel: x7 : 0000000000000090 x6 : 00000000f5d00010
Dec 8 03:57:41 kernel: x5 : 00000000000022a8 x4 : 00000000f5df5168
Dec 8 03:57:41 kernel: x3 : 00000000674e206f x2 : 00000000f5df5168
Dec 8 03:57:41 kernel: x1 : 0000000000000000 x0 : 00000000f5d00010
Dec 8 04:04:37 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 04:07:36 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 04:09:01 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 04:13:01 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 04:18:57 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 04:18:58 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 04:19:00 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 04:19:02 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 04:19:05 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 04:19:07 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 04:21:01 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 04:21:30 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 04:43:02 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 05:04:01 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 05:13:04 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 05:19:01 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 05:43:06 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 06:04:01 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 06:08:27 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 06:13:07 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 06:19:01 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 06:43:09 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 07:04:01 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 07:13:10 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 07:19:02 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 07:43:12 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 08:04:02 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 08:13:13 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 08:19:02 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 08:43:15 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 09:04:02 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 09:13:16 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 09:19:02 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Dec 8 09:43:18 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
MasterC
Community Admin
Community Admin
Hi There,
Have you already used the feedback function? Have all three boxes checked.
69436
_____________________________________________________________
FPS, Racing, and VR Gamer / Tech Enthusiast / ROG Admin
Of course..
But no email back to say if it is anything to worry about.
No communication is worrying as I paid nearly £400 for this garbage.
Two GT-AC5300 and both have faults.. sent the old one back and got this one and it has faults..
I don't understand why can't you give us a firmware that you have made so far.
