Replacement screws for G20AJ
sf0614r18
I'm looking for replacement screws for my G20AJ.
I'm speaking of the very tiny screws that are used to open the case, access the GPU etc.
I lost at least 4 of them and want to replace them.
Does anybody know what is the proper size of these screws or where they can be purchased?
JustinThyme
Problem is determining the screw size, finding them after this is known is easy.
Hi! I have the same issue. Did you find those screws in the end?
Nevermind, I found them myself. For anyone wondering, they are M2 x 4mm Phillips Flat Head Screws.
