Questions / help with upgrading G20AJ GPU
ruby2512
I currently have the G20AJ with Intel i7-4790, 16GB RAM, GTX 960 and it came with 2 power supply ( 180w and 230w ).
Will this 1080 fit and run with enough power? https://www.newegg.com/Product/Product.aspx?Item=N82E16814126110&cm_re=gtx_1080_turbo-_-14-126-110-_...
If the asus gtx 1080 turbo doesnt fit/work with my G20AJ, will this ZOTAC 1080 mini work? https://www.amazon.com/dp/B01NCVICRY/ref=nav_timeline_asin?_encoding=UTF8&psc=1
0 REPLIES 0
