12-04-2017 10:42 AM - last edited 3 weeks ago by ROGBot
12-04-2017 09:22 PM
01-03-2018 04:55 AM
JustinThyme wrote:
Firstly, it will never be bootable
What adapter did you buy?
If it doesn't seat in properly as in making contact with the correct pins its not going to work. If its a single NVMe adaptor it should be X4 and fit to the end of the slot as in left side for most appllications. You cant just poke it in any which way. All of the connections are specific.
After getting a card that fits correctly it should be plug and play, maybe Samsung drivers for the 960 if you want but even that isnt necessary. It just wont boot as the drivers wont be loaded until you get into the OS. Boot from PCIE just came mainstream with the newest boards.
What card did you and what slot are you trying to put it in?
01-03-2018 07:07 AM
01-03-2018 08:22 AM
