Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
    untouched Array Praz's Avatar
    Apr 2011
    137
    4,037
    Understanding and using XMP
    XMP is often viewed as plug n' play when overclocking memory. As is the case when overclocking other system components memory stability may not be achievable by simply enabling XMP.
    XMP will have been fully qualified by the memory manufacturer. This testing is done on a sample of boards the manufacturer has in there possession and/or by machine testing. The motherboard manufacturer likewise qualify specific memory sets for motherboards using provided memory sets, board samples and design/test data. The following are important considerations to keep in mind when relying on XMP as an overclocking option:
    Using XMP is not running the system at default stock settings. Any memory setting that differs from JEDEC or processor manufacturer specifications is an overclock.
    XMP is valid only for the set of memory that is purchased. Mixing modules or combining kits results in the XMP profile being no longer valid.
    Regardless of what may be assumed from marketing XMP does not guarantee automatic overclocking. The tighter the timings or higher the frequency compared to stock specifications the more likely chance there is that the user will need to manually make some adjustments for stability.
    To increase the probability of XMP being successful and when overclocking memory in general purchase memory kits one or two bins lower than the maximum the motherboard is qualified for.
    The biggest variable of XMP being successful will be the capabilities of the processor's IMC. As with CPU speed memory overclocking success will vary from one CPU sample to the next.
    When enabling XMP it is normal and should be expected that the board will alter other settings as well as voltages. These changes are set up to accommodate the processors at the lower end of the lot sampled. Especially with voltages it is the responsibility of the user to change these values to amounts that suit the particular CPU and configuration being used. Below are examples of some of the voltages that were altered by enabling XMP. As can be seen this CPU requires considerably less IO, SA and Standby voltages for stability than initially set.
    XMP enabled
    XMP enabled with IO, SA and Standby voltages adjusted to match the needed values for the CPU
    ROG Guru: White Belt Array SherardG PC Specs
    SherardG PC Specs
    Laptop (Model)ASUS ROG G752 & ASUS ROG G55VW
    MotherboardASUS ROG Maximus X Hero
    ProcessorIntel® Core™ i7-8700K
    Memory (part number)32 GB [G.Skill TZRGB] F4-3200C32Q-8GTZR x 4
    Graphics Card #1ROG-STRIX-GTX1080TI-O11G-GAMING
    MonitorASUS ROG PG248Q
    Storage #1Samsung 960 PRO MZ-V6P512 (512 GB)
    Storage #2WD2003FZEX
    CPU CoolerNZXT Kraken X62
    CaseNZXT Noctis 450 ROG
    Power SupplySeasonic PRIME 80+ Ti 750 SSR-750TD
    Keyboard Logitech G413 Carbon
    Mouse Logitech G502 Proteus Spectrum
    Headset Razer Kraken Pro V2 Black
    Mouse Pad Logitech G440
    OS Windows 10 10.0.16299
    Network RouterASUS RT-AC88U
    SherardG's Avatar
    Nov 2017
    101
    Thanks for this comprehensive guide! When you lowered the VCCIO, SA, and CPU Standby, how did you arrive at these values?
    Is your 8700K Delidded? That temperature is low!
    On a vacation Array
    Nov 2017
    32
    No hard feelings towards the OP (it's not his fault anyway), but why do I get the feeling that this thread was made sticky as a response to my complains? If I'm right, that'd be SO infantile...(yet again).
    But OK, I'll bite. Loaded BIOS defaults, and the only option I modified is SVID at Best Behaviour (so XMP is disabled and RAM at default 2133, also verified that in HWiNFO64). And the voltages are still EXACTLY THE SAME, and I'm still having EXACTLY THE SAME ISSUES as when I have it enabled.
    Next excuse, please?
    Apr 2011
    137
    4,037
    Quote Originally Posted by SherardG View Post
    Hello
    Change the voltages or settings in small steps and retest for stability. In this instance I know what this CPU is capable of so I set 1V for all 3 settings. With further tuning the voltages can most likely be reduced further in this instance. Yes, the CPU is delidded.
    Quote Originally Posted by Dovakhan View Post
    Hello
    See my post in your latest thread.
    https://rog.asus.com/forum/showthrea...l=1#post690773
    Administrator Array Silent Scone@ROG's Avatar
    Mar 2016
    233
    2,708
    Great post, Praz. Covers ground that most users often overlook.
    I think you're flattering yourself too much. This is basic ground when it comes to memory overclocking and buying binned kits, and something that comes up time and time again. Memory is a complex subject that can't really be covered completely as it's outside the scope of what the end user will understand. What this post from Praz does, is tell you exactly what the profile does and the implications of it. Whether one chooses to accept that or not is down to that individual.
    ROG Guru: Yellow Belt Array Carbonicdk PC Specs
    Carbonicdk PC Specs
    MotherboardAsus ROG Strix Z370-E Gaming
    ProcessorIntel i7-8700k
    Memory (part number)F4-3600C16Q-32GTZR
    Graphics Card #1Asus ROG STRIX GTX1080TI O11G GAMING
    Sound CardSchiit Modi 2 Uber
    MonitorAsus MG278Q
    Storage #1Samsung 960Evo
    CaseFractal Design Define R6 - Tempered Glass
    Power SupplyCorsair Professional Platinum Series AX860
    OS Windows 10 64bit
    Mar 2016
    143
    Probably also doesn't help that Z370 got released early and thus tends to have issues with XMP and memory overclocking in general. Bios probably needs a lot of work and there's sadly not been as many updates as I expected there would.
  7. #7
    On a vacation Array
    Nov 2017
    32
    Quote Originally Posted by Carbonicdk View Post
    I'm emailing ASUS support about those issues, seeing how the mods here are more interested on deleting messages rather than reporting them to the techs and giving status updates. It'd be nice if everybody with those voltage issues here did the same.
    Now, if only they could reply more than once a week, maybe we could get all the issues solved.
  8. #8
    Apr 2011
    137
    4,037
    Hello
    This thread is for XMP specific topics only. It is not a dumping ground general whining and moaning. All future off topic posts will be removed without notification.
  9. #9
    ROG Enthusiast Array
    Jun 2017
    31
    delete because offtopic^^
  10. #10
    ROG Enthusiast Array theWanderer521 PC Specs
    MotherboardROG Strix Z370-E
    Processori7 8700k
    Memory (part number)Corsair Vengeance 32Gb 3200MHz
    Graphics Card #1Aorus GTX 1080 Ti
    MonitorAsus 27" and 23"
    Storage #11 TB Seagate HHD / 2 TB Seagate HHD
    Storage #2500 GB Samsung EVO
    CPU CoolerCoolerMaster MasterLiquid 240 AIO
    CaseCougar Panzer Mid-Tower Chassis
    Power SupplyCorsair RM750i
    Keyboard Logitech G810 RGB Orion Spectrum
    Mouse Logitech G102 Prodigy
    Mouse Pad VIPAMZ XL Mouse Pad
    OS Windows 10 64 bit
    Dec 2017
    62
    Amateur in XMP Profiles
    ROG Strix Z370-e / i7 8700k
    Hi new member here. I am no expert in overclocking etc.
    I recently bought this PC (all brand new parts) few weeks ago. For being stupid (stupid coz I just updated BIOS just for the update) , I decided to update my BIOS to 5605 from 0419. I also enabled XMP profile. MCE disabled.
    Right now I have fluctuating CPU temps that I have never encountered on the previous BIOS build.
    Though it is stable like I can boot to Windows..do my normal stuff (browse etc.) It's just I have fears regarding these temps. Should I be worried? Should I downgrade to previous BIOS? I also experienced 85c in normal 3D sketchup renders....
    If anyone can try to help and point me on any particular setting to adjust on this latest update I would greatly appreciate it.
    Furthermore, I haven't done OC this one or any delidding or any expert stuff. Thanks once again!
