Results 1 to 6 of 6
    ROG Enthusiast Array
    Sep 2013
    40
    G751JY keyboard suffered a small spill. How hard is it to replace? Correct part?
    I spilled a little chicken soup on my keyboard. It was a pretty small amount so I just wiped it off... I was watching youtube at the time, not really doing much. About 20 minutes later I went to type something and when I press a few keys (such as P or O), it gives a back slash, jumps to home (like it thinks I hit the "home" key), or some other things. I shut the laptop off and unplugged it after that.
    I'm going to leave it up side down over night but I'm worried that I may have permanently damaged the keyboard... so I am consideirng ordering this replacement on amazon
    https://www.amazon.com/Eathtek-G751J...EGKERNJ642YKM2
    Do you think replacing JUST the keyboard is enough or should I replace the whole panel (like here http://www.asusparts.eu/images/Artic...6G1-R30280.jpg )
    If just the keyboard is okay, how hard is it to do? I hear Asus laptops are notoriously hard to take apart. I have done some small "computer surgery" before, like installing a GPU inside a desktop, but not much experience with laptops.
    ROG Guru: Gold Belt Array Clintlgm PC Specs
    Clintlgm PC Specs
    Laptop (Model)Asus G752VY DH72
    MotherboardAsus Z97 Pro WiFi and /Z97 Pro A
    ProcessorI7 4790K
    Storage #1512 GB M.2 Samsung 960 Pro
    Storage #21 TB Samsun 850 Pro
    CaseCool Master Haf
    OS Win 8.1 Pro and Win 10 Pro
    Clintlgm's Avatar
    Jul 2012
    105
    4,135
    There are videos on YouTube on how to disassemble and reassemble be very careful with ribbon and connectors they are all delicate and easily damaged
    Only you can see what else will need to be replaced. Most are more or less totaled with a liquid spill effecting the motherboard also especially since you turned the unit back on with the liquid in there. Sometimes I have read that all can be soaked in Alcohol cleaned and dried out and will function again. You will have to open it up to see if the soup penetrated they keyboard down onto the rest of your notebook internals. Generally speaking notebooks that have liquids spilled into them don't survive. We all know this and have all been warned to keep liquids far away from our notebooks.
    G752VY-DH72 Win 10 Pro
    980m GTX 4 GB
    32GB DDR 4 Standard RAM
    Z97 PRO WiFi I7 4790K
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
    Sep 2013
    40
    I don't think it's quite as bad as that. It still boots up, at least. Although at least one keyboard button is stuck on, about 12 hours of being upside down with a fan pointed at it later...
    ROG Guru: Black Belt Array toronto699 PC Specs
    toronto699 PC Specs
    Laptop (Model)G752-VY-DH78K , G751-JYDH72X
    MotherboardRog Tytan G30AB
    Processori7-4770K
    Memory (part number)32GB
    Graphics Card #1Asus Gold20th GTX980Ti
    Sound CardDell X-Fi Audigy SoundBlaster
    Monitor3 Acer K272HL
    Storage #1118 GB/OS
    Storage #22.72 TB
    CPU CoolerIntegrated Liquid-Cooled CPU
    CaseG30AB
    Power SupplyAsus 700 Watt
    Keyboard Razer BlackWidow Ultimate
    Mouse Razer Diamond Back
    Headset Sony Studio Professional , Razer Seiren Mic
    Mouse Pad Razer FireFly
    Headset/Speakers Logittech 5.1 Z-5500
    OS W 10
    Network RouterSagemon Fast 5250 Hub 2000
    Aug 2014
    96
    2,476
    Rubbing Alcohol And a Q Tip , Lillle at a Time to clean in under the Key , Let it dry few hours , Key may work after
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,857
    Depending on how bad it is and if its already worn in the first place.
    You may be able to remove it and use electronic parts cleaner on it but that may dry out some of the keys and change the color and feel.
    If it was me Id be going for the OEM panel over the aftermarket keys that is a C&P from a Chinese Ebay listing. Yes Amazon will back it up but would it be worth the PITA of disassembly again. With the full panel you simply remove and replace the top and as Clint pointed out the hardest part are the ribbon cables. They are just tiny and the connectors are flimsy. Toast a connector on the MOBO and you have screwed the pooch! If you attempt the Chinese keyboard then you still have to disassemble the top and remove it then replace the keyboard section in the top so a lot more work.
    By far the most difficult part is getting the top off in the first place. Once youve done it a time or two it becomes easy though. Lots of vids that show it. Just search your model and "disassembly". For the most part its just locating the screws from the bottom, popping off the center cover over the hinges in the rear then getting under one of the corners in the back with a thick plastic card. I use two magnetic hotel room keys (Had them from business trips, who doesnt end up with these!) and get them under the edge in the back and start sliding them to the front and around. When you get to one of the catches you will hear a slight pop as it lets go. (same putting it back together)
    Sep 2013
    40
    I would replace the whole front panel, but I can't seem to find one for sale. Where do you usually get this type of thing?
    Edit: I have found the whole panel
    http://www.asusparts.eu/en/Asus-90NB06G1-R30280
    But it's 100$, as opposed to just the earlier posted standalone keyboard which is 20$... agh.
    Any experience with that site, at least? It says "zand parts", so I don't think this one is OEM either...
