Results 1 to 3 of 3
    ROG Enthusiast Array ddmeltzer8 PC Specs
    ddmeltzer8 PC Specs
    Laptop (Model)-
    MotherboardAsus prime B-250 plus
    Processori5 7500 kaby lake
    Memory (part number)2x8GB HyperX fury
    Graphics Card #1Asus Strix GTX 1060 6GB
    Graphics Card #3-
    Graphics Card #4-
    Sound Card-
    MonitorAOC Q2577PWQ (60 Hz)
    Storage #1Intel SSD M.2 540s Series 480GB
    Storage #22x Samsung 850 EVO 250GB
    CPU CoolerFractal Celsius S24
    CaseFractal define C windowed
    Power SupplyCorsair TX550M
    Keyboard Corsair K70 Lux
    Mouse Roccat Kone Pure Owl-eye
    Headset Sennheiser HD 555
    Mouse Pad Corsair
    Headset/Speakers Harman Kardon HK 395
    OS Win 10 Pro
    Network RouterZyXEL VMG 8924
    Accessory #1 Asus PCE-AC55bt networks card
    Accessory #2 -
    Accessory #3 -
    ddmeltzer8's Avatar
    May 2017
    70
    strix 1060 idle temps???
    Hello,beautiful forum.
    My strix 1060 runs at 55-60 c when idle and I feel its a bit hot...I am using msi afterburner for monitoring without any OC at all!Everything is default.
    I have also noticed that the fan keeps "pulsing" where it didnt before.It doesnt matter how I set the fan profile.But its not all the time,very random.Its very annoying!
    I appreciate all help I get!
    Thanks.
    ROG Guru: Grand Master Array
    Oct 2012
    339
    15,255
    Idle temperatures vary depending on your ambient temprature and airflow inside your case. It's normal for the GPU to get around 55-60C because the 0db function doesn't turn on the fans until temperature reach a certain limit. If you prefer the lowest idle temperature possible, you can modify the fan curve. GPU Tweak II has different profiles for the GPU. Or you can manually make your own in the program of your choice.
    ddmeltzer8 PC Specs
    Laptop (Model)-
    Graphics Card #3-
    Graphics Card #4-
    Sound Card-
    Mouse Pad Corsair
    OS Win 10 Pro
    Accessory #2 -
    Accessory #3 -
    ddmeltzer8's Avatar
    May 2017
    70
    Quote Originally Posted by Chino View Post
    Thanks,but IO dont think u understood the question.
    Anyway,I contacted ASUS and they came to the conclusion that the card is faulty.So I'm going to return it.I have had several issues with ASUS hw recently and dont think I will ever buy ASUS again.
    What card do u use?
    R u happy with it?
    Cheers.
Tags for this Thread
