Results 1 to 4 of 4
    New ROGer Array
    Aug 2013
    6
    Angry Crosshair VI Hero WiFi no POST
    Right, so, the short version of my problem. Last Thursday everything was going fine until I got a BSOD and an instant restart, and my computer wouldn't POST. Q code 90, VGA light lit. RMAd board to ASUS, but I couldn't wait so I bought a brand new board, same make and model, same problem. Bought a new graphics card (RX 460) to use as a test, same problem. Replaced the power supply and cables, same problem. Tried with no storage attached, same problem. Only thing left I can think of is the CPU, but it passes the boot tests...
    ASUS Crosshair VI Hero WiFI
    AMD Ryzen R7 1800X w/ Corsair H115i
    2x8GB G.Skill Flare DDR4-3200
    Sapphire Radeon Fury Nano
    Samsung 960 Pro 500GB NVMe SSD, 2x Samsung 850 EVO 1TB SSD
    SeaSonic SSR-750TD 750w 80 Plus Titanium PSU
    ROG Guru: Yellow Belt Array unknownmiscreant PC Specs
    Laptop (Model)Dell E430s (i7)
    MotherboardCrosshair VI Hero
    ProcessorRyzen 7 1700X
    Memory (part number)F4-3200C14D-16GFX (Currently clocked 3466MHz)
    Graphics Card #1EVGA GTX1070 FTW
    Sound CardAsus Strix Soar
    Monitor2x Dell U2412M
    Storage #1Intel 540s
    Storage #2Intel 520
    CPU CoolerEK Supremacy Evo
    CaseCorsair 460x
    Power SupplyEVGA 850 G2
    Keyboard Logitech G610 Cherry MX Brown
    Mouse Logitech G502
    Mouse Pad Logitech G640
    Headset/Speakers Custom built sound system
    OS Win 10
    Network RouterNetgear Nighthawk
    Jul 2017
    180
    Try reseat, the ram, GPU, cpu and cpu cooler. (Try not fully tightening the screws and giving it a wiggle side to side to ensure all pins make proper contact.)
    Also try a different PCIe slot. Have you got the auxiliary power connected? (Although I think thats a 62.)
    New ROGer Array
    Aug 2013
    6
    Quote Originally Posted by unknownmiscreant View Post
    Reseated everything when I swapped mothereboards, tried both PCIe x16 slots, have all board power connectors and GPU connectors attached. Everything worked perfectly form July 5th to November 28th.
    New ROGer Array
    Aug 2013
    6
    Alright, so, the problem was indeed the processor, most likely the integrated PCIe controller. I bought an R3 1300X and it works like a charm. I encourage ASUS to look into this as the error code indeed showed a VGA problem and not a CPU problem, and it cost me $19 in a useless motherboard RMA.
