What cable to use on usb 3.1 on I/O plate (Z270E)
FIIZEEX
hello
i have Galaxy s8 i want to take the full speed from usb 3.1 on I/O plate
What cable do i use ( usb type c to usb type c ) or ( type A to type C )
i see some cable they say Gen 1 or Gen 2 is there is a difference ?
qUAanA
The Galaxy 8 takes USB C so you can take advantage of that.
Hope this helps
Hope this helps
Yes i know that , i mean how do i get the full speed is there is a different between ( USB type c to type c cable ) and ( type A to C cable ) ??
and also there is gen 1 and gen 2 cables ?
thanks in advance
up.....
