Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 39
    New ROGer Array
    Nov 2017
    9
    Rampage VI Extreme is pure disaster
    Current rig.
    Rampage VI Extreme
    Intel 7980XE
    Intel SSD 900P 480gb
    Samsung SM863 2tb
    WD Gold 10TB x4 (RAID 10)
    Megaraid 9361-8i
    AMD Vega FE
    64GB Trident Z RGB, DDR4 3600MHz, CL17
    + custom WC loop
    I have never experienced so much trouble than from this MB.
    Bios 0802 is causing random lockups (every 15-30min) and gets stuck on the boot
    Bios 1002 can't shutdown (goes to just back to login screen and gets stuck on the book, so this is not viable option too.
    Bios 1004 "works" but it still has stability problems. It hangs and gets stuck on boot "only" every few days and it wont overclock as well as in 1002 (event with everything in stock, no overclocking or XMP).
    ...then we get to Fall Update compatibility issues, well I have tried to install different W10 builds on every bios version (except 1003 as it has same problems as 0802 and 1002). After 20-30 installs the conclusion is that board is not compatible with the Fall Update on any bios versions OR any driver versions available OR any ISO versions from the MS (September and November versions).
    Immediately after clean install Edge freeze while browsing, explorer hangs when creating shortcut to the desktop... so basically windows build 1709 is not usable. Some times I got usable Windows when I upgraded from the 1703 to 1709 but still I'm not too confident on this route also as I got random problems also which are not present on 1703.
    Only stable version for me is currently 1703. I have tested with other cpu and memory with the same results.
    I noticed that all these issues were quite wide spread as other complain from the same issues (here and other forums) and latest posts from the MS support forum is not encouraging as they blame Asus from their broken bios.
    ...then all this with failed VRM cooler design is enough.
    Even thought all these problems (well except the VRM design) are correctable by the future BIOS updates I'm going to RMA this board and send it back.
    Asus lost my faith and soon going to test Asrock Fatal1ty X299 Professional Gaming i9 XE.
    I have never seen this broken flagship MB from Asus. It's quite a mystery how they release the product when they must have known in advance that their BIOS is not stable enough. I'm not going to be beta tester with the workstation which I should work and rely on my daily work.
    End of RANT.
    Administrator Array Silent Scone@ASUS's Avatar
    Mar 2016
    124
    1,819
    As you've already made up your mind, there's no need to probe you with questions. However:
    1) There are users running those MS builds (including Insider Previews) without the problems you are having
    2) All the other issues sound like instability, or an underlying issue with the system and/or configuration rather than a fault with the motherboard. I would recommend in future possibly using a system integrator if these things are giving you this much trouble.
    New ROGer Array
    Nov 2017
    9
    oriente h100
    Quote Originally Posted by Silent Scone View Post
    I'm not saying that everyone got problems with the fall update, but it's quite significant problem as this issue has been raised multiple times here and ms support forums with official MS responding that Asus has broken BIOS.
    Stability issues are by the bios are also reported here multiple times, if clean install of the os can't stay up then no one can't help until the bios is fixed. I have build my workstations for the last 20 years and this is the first time I have ever encountered this much trouble. I do also blame on MS for bringing those updates which causes lot of other problems and this has got worse when MS moved to semiannual releases (latest Fall Update caused lot of 3rd party software issues).
    ROG Guru: Orange Belt Array mpoffo PC Specs
    mpoffo PC Specs
    MotherboardRampage VI Extreme
    ProcessorIntel 7900x
    Memory (part number)G.Skill F4-3200C16Q-32GTZR = 32 GB 3200 Kit
    Graphics Card #1Nvidia Geforce 1080 FE
    Graphics Card #2Nvidia Geforce 1080 FE
    Sound CardSound Blaster Z
    MonitorNvidia Surround (5960 x 1080)
    Storage #1Samsung 840 Pro256 GB/850 Evo 500 GB
    Storage #2WD 2 TB & 4TB Black Hard Drives
    CPU CoolerCorsair H115i
    CaseCorsair 900D
    Power SupplyCorsair 1200i
    Keyboard Corsair K95 - RGB
    Mouse Corsair Glaive
    Headset Turtle Beach Surround
    Mouse Pad Corsair MM800 RGB Polaris
    Headset/Speakers Logitech 5.1 Surround THX Speakers
    OS Windows 10 Pro - 64 Bit
    Network RouterNetgear Nighthawk x10 R9000 w/ Plex
    Accessory #1 Corsair Comm. w/ Corsair HD Fans - NZXT Hue +
    Accessory #2 DX Racer King Series Chair
    Accessory #3 3D Printer/HTC VIVE
    mpoffo's Avatar
    Jan 2013
    17
    254
    Quote Originally Posted by grayl View Post
    I will add that I have had issues with the fall creators update as well not allowing for shutdown. Not sure if it board related but I decided to stick with 1703 for now until it matures and things get sorted. Working fine on 1703 with no issues.
    RVIE X299 System:
    Windows 10 Prof 64-bit | Intel Core i9 7900x | ASUS Rampage VI Extreme | Corsair AX 1200i PSU
    Corsair 900D | 32 GB 3200 G.SKILL Trident RGB Series | EVGA GTX 1080 in SLI (x2) | Nvidia 2D Surround Set-up
    Samsung 840 PRO 256 GB | Samsung 850 EVO 500 GB | Intel 520 SATA SSD 240GB HD | 2 & 4 TB WD Black Hard Drive
    Creative Sound Blaster Z | Logitech THX 5.1 speaker setup
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,858
    The fail to shut down is not a BIOS issue, thats FC update.
    1703 is the latest stable non problematic OS. 1709 is problematic for a lot of platoforms. Im on 1703 and staying there.
    0802 has known issues with the 7980 CPUs, works fine on the 7900X. When this board first rolled out there were no retail 7980s.
    For someone with this much experience I would think you would take time to go one thing at a time and not jump into so many variables at once. I would also expect you would know that you can run older versions of Windows and older builds of win 10.
    Whats wrong with the VRMs? Are you experiencing over heating. All X299 manufacturers had VRM issues early on. They have since corrected them.
    Edge freezing is not the MOBO in the least. I dont understand using something that has had and continues to have issues. Use a reputable browser, Chrome, Firefox, Opera to name a few. Edge is a junk refresh of IE that is actually worse as they tried to make something that doesnt work in the first place perform even more tasks.
    Before jumping ship you should read other forums of the other manufacturers first. They all have one issue or another. Most of this is just growing pains you will experience from being an early adopter of any technology.
    RMA does not mean you get a refund.
    you should check with whoever you bought he board from and check their return policy. Some have no returns, some have 14 days and some have 30 days. None go past 30 days.
    ROG Guru: Brown Belt Array Brighttail PC Specs
    Brighttail PC Specs
    Laptop (Model)Asus G751JT
    MotherboardAsus x299 Rampage VI Extreme
    ProcessorIntel i9-7900x
    Memory (part number)Corsair Dominator Platinum SE 3200Mhz 4x8
    Graphics Card #1MSI GTX 1080TI
    MonitorAcer XB321HK (4k,IPS,G-sync)
    Storage #1Intel 900p (Boot) 2xSM961 (RAID 0) Games
    Storage #2Samsung 850 Pro 512GB - WD Black 4TB
    CPU CoolerCustom Water Cool
    Power SupplyCorsair AX 1200i
    Keyboard Corsair Platinum 95
    Mouse Asus SPATHA
    Headset/Speakers Kanyo Y5
    OS Windows 10 64 bit
    Accessory #1 2 x Alphacool Full Copper Radiator 420mm/280mm
    Accessory #2 Monsoon MMRS reservoir w/ 2 x D5 Vario Pump
    Accessory #3 Monsoon Free Center Compression Fittings
    Sep 2014
    33
    1,332
    I would go to 1002 and use the work around in the Power Options and do the shut down fix that is well documented in these forums and on Google.
    Panteks Enthoo Elite / Asus x299 Rampage VI Extreme / Intel I9-7900X / Corsair Dominator Platinum SE 4x8 3200MHz
    MSI GTX 1080 TI / 2x Intel 900p in a bootable VROC RAID 0 / Samsung 960 Pro 512GB
    Samsung 850 PRO 512GB / Western Digital Gold 8TB HD
    Corsair AX 1200i / Corsair Platinum K95 / Asus Spatha
    Acer XB321HK 4k, IPS, G-sync Monitor / Water Cooled / Asus G571JT Laptop
  7. #7
    ProcessorI9 9940X
    OS Win10 Pro 1809
    Nov 2013
    144
    3,858
    Quote Originally Posted by Brighttail View Post
    Shut down fix is rather easy, disable fast start up.....done.
  8. #8
    ROG Guru: White Belt Array
    Dec 2011
    97
    While I was testing the board, CPU & memory prior to case installation I've done multiple clean installs using the 1004 BIOS and build 1709 and have had no issues so far. Just sayin'.
  9. #9
    ROG Guru: Orange Belt Array restsugavan PC Specs
    MotherboardRAMPAGE VI EXTREME
    ProcessorCore i9 7980XE
    Memory (part number)64GB GSKILL TRIDENT-Z RGB 3200
    Graphics Card #1ASUS ROG POSEIDON 1080Ti
    MonitorSAMSUNG UD590D
    Storage #1INTEL600P 1TB
    Storage #2WD 4TB External HDD
    CPU CoolerNZXT KRAKEN 62
    CaseCorsair Carbine 540
    Power SupplyCorsair AX1200i
    Keyboard Microsoft
    Mouse Microsoft
    Mouse Pad ASUS
    Headset/Speakers Sony
    OS Windows 10 2019 Insider Preview 19002.1
    Network RouterD-LINK
    restsugavan's Avatar
    Sep 2017
    36
    391
    I think VRM is not issue here. Maybe PCIe-RAID card issue incompattible with UEFI BIOS. 7980XE working witg R6E very well since 0802 on my system.
    1002 BIOS is good but it may cause intel turbo boost 3.0 app crashed. 1003 and 1004 are on par together.
  10. #10
    New ROGer Array
    Nov 2017
    9
    Quote Originally Posted by restsugavan View Post
    http://www.overclock.net/t/1632665/i...#post_26444162
    There is good post comparing R6E & FXE VRM design. I do run monoblock, but want to test Kryos from Aqua. In R6E without putting small noisy fan or some other fan setups taking care of VRM cooling, VRM is going to cause throttling.
    I didn't notice Turbo Boost problem on BIOS 1002 but the amount of different problems people are facing is direct indicator that current status of the BIOS that is not stable. Also when you publish so many BIOS revisions in just 1-2 months tells me that Asus is trying to solve at least in acceptable fashion that people don't return their boards (or RMA them).
    I do have tested without RAID card, without success. I did how ever notice that Intel Optane 900P has some driver issues with the NVMe. When working with VROC driver, many randon issues were solved.
    Today I'm receiving new RAID card (MegaRAID 9460-16i) which can run NVME drives if it's going to change anything on this matter. Intel 900p have PLP (power loss protection) but it lost data during testing (when I was experiencing random lockups) when running VROC drivers.
    I'm not sure if this is caused by OS, driver, bios or combination of them but this is first time I have encountered data corruption / loss for very long time as I have always run my drives from the Megaraid RAID controllers.
Tags for this Thread
