[Build log] Project Metallurgy - A metal scratch build
PinePCdesign
First time posting on the ROG forums, hope you guys enjoy my content. 😄
Time for another Scratch Build!
Theme:
The Process industry
Sponsors
A huge thanks to the sponsors named below, this project would not be possible without your support!
Alphacool
Cooler Master
Cablemod
TeamGroup
Apacer
Links to Updates
Update 1:
Frame parts and test-tapping thread
Update 2:
Paint effects and test fit
Update 3:
Alphacool CPU block + Eisfluegel
Update 4:
Cooler Master PSU + RGB fans
Update 5:
Sanding + Polishing steel pipes
Update 6:
Asus Strix Z370-E Gaming
Update 7:
Asus Strix 1080ti + TeamGroup Delta RGB
Update 8:
The new frame!
Update 9:
Delid & Watercooling components
Update 10:
Paint details & Test fit
Update 11:
Cables & Lighting
Update 12:
Almost done and first event!
Update 13:
Final pictures!
3D Sketch
Hardware:
CPU: I7 8700k
Mobo: Asus Z370-E Strix
GPU: Asus Strix 1080ti
PSU: Cooler Master V750
Fans: Cooler Master Masterfan Pro 120, AP RGB
RAM: 16GB T-Force Delta RGB
Storage: 2x 240GB Apacer SATA SSD
Watercooling
(Obviously all Alphacool):
Pump: Eispumpe VPP755
Reservoirs: Eisbecher 250 Acetal
GPU block: NexXxoS GPX
RAM block: D-RAM with D-RAM modules
CPU block: Eisblock XPX
Rads: NexXxoS XT45 480
PCI-e cooler: Eisblock HDX-3
Fittings: Eiszapfen + modding packs
Pipes: Brass Hardtubes 13/10mm + PETG 13/10mm
31 REPLIES 31
PinePCdesign
First update on the project, the parts for the frame came in!
Metal scaffolding pipes
The fittings with the aluminium sheets, they look so goddamn good! Loving the industrial look.
Trying to tap threads into the fittings that will attach the aluminium sheets to the frame. Works like a charm!
That was the quick first update.
Next I’ll test some different painting effects on the fittings and metal sheets.
xeromist
Cool! Are you going to weigh it when you're done? 😄
Thanks Xeromist!
Lmao most definitely, it'll be the heaviest PC case of it's size for sure.
It won't be very practical, but it will be amazing. 😄
PinePCdesign wrote:
Thanks Xeromist!
And one benefit: if the burglars break in, they won't be able to carry it off. Leave a dead iPhone for them as a shiny metal object
Second update, let’s begin with some nice metal flakes to complement the theme… 😉
All threads tapped, good stuff!
Not sure what I’m going to do with the frame and aluminium plates, so I tested some effects on the fittings and pipe.
I’d like to hear what you think of this!
Test fitting the aluminium plates onto the metal fittings and pipes.
The aluminium plate was bent at my brother’s work, where they have all the machines to work with metal.
That’s one big PC, but it’s going to be hella pretty!
Closeups of some Alphacool products for this project.
The Alphacool Eisblock GPX will be paired with a modding kit for the same block in blue.
The modding top
The Eisfluegel flow meter.
And of course, the chrome Eisblock XPX. I’m not sure if I like the dark-blue logo, so I’ll probably change that to another color (white?) that came with the modding kit.
Thanks for Cooler Master for sending me the PSU and fans!
First off: some fancy shots of the Cooler Master V750 modular psu which is going in the system.
Hope you guys like this stuff, at the moment I’m just trying out different backgrounds so let me know if you like it.
“Cooler Master Masterfan pro 120 RGB air pressure fans”
Jeez what a mouthful… They’re beautiful though. Can’t wait to light them up.
Cooler Master RGB Controller that comes with the 3-pack.
Will hook up 4 fans to both the controllers, each for one radiator.
This time will be a small update, as a follow-up on a few updates earlier.
In update 2, I showed some test paint-effects on the aluminium plates. I’m not sure what to do with the plates yet, but decided to polish the steel pipes.
The pipes will be sanded and lightly polished.
On the picture below the pipes have just been sanded, but still have to be polished.
The polishing will erase the bigger scratches, but the metal will keep a light brushed look.
Holy crap! That is so freakin cool! I always wanted to build something like this, how good are those RGB 120's? Do they move a lot of air?
1950x / Zenith Extreme ROG / R9 290x 4gb / Win 10 Pro
K6-III+ 450mhz @ 550 / ASUS P5A-B / 3dfx Voodoo 5500 64mb / Win 98 SE
