Results 1 to 2 of 2
    ROG Member Array
    Sep 2015
    15
    Does Z370-I support surround sound over S/PDIF optical?
    It is a bit unclear when I look at the specs for the Z370-I if they have multi channel support for this motherboard over the optical output? What about Dolby/DTS-support?
    I'm asking because I can't get my Steelseries Wireless H headset setup with multiple channels on my brand new computer(Win 10 pro with creators fall update). There is no option to choose anything but 2 channel 16 bit 48000 hz in sound settings in Windows.
    And Asus support takes forever to answer so I figure I just ask here and see if anyone knows if I am even supposed to get this to work?
    Kind regards,
    Bokai
    ROG Member Array
    Jan 2013
    6
    i have the same setup and problem i cant set DD or DTS. Asus support takes forever to answer
Tags for this Thread
