Pubg and low fps. GL 752vw
auleee
Hi guys. Ive got pretty low fps - around 25-35 during combat or around lots of objects. Thats pretty annoing, i wonder if i could somehow get more with my setup.
CPU i7-6700HQ 2.6 ghz
GPU GeForce GTX 960m 4gb
32gb ram, ssd
burning_ac1d
Have you checked the pubg settings, there are limitations in FPS you can set, before stating to play.
Also try to update your gaming driver.
i have the same pc and the same issue tried to replace everything inside it and it didnt work
TimeLion724
From what I know they fixed that problem after the game was optimized. First-Person mode works fine but the Third-Person/First-Person mode had the problem.
" The speed of the fallen one does not change..."
GUIDE TO FIXING BSOD ERRORS
