Results 1 to 4 of 4
    ROG Guru: White Belt Array
    Aug 2013
    94
    Exclamation Need driver for PG278QR
    Hello
    I´m having troubles with my 3D Vision, when i run in 3D the display is not detected as a 3D capable monitor and i get the red warning message.
    Is there any driver out there? Cause the only solution that i find, was putting resolution at 1280xsoemthing at 120hz, and that´s the only way that he plays without a problem
    I have minor ghosting to
    ROG Member Array Mazinga PC Specs
    Mazinga PC Specs
    MotherboardASUS ROG Maximus X Hero Z370
    ProcessorIntel Core i7-8700K 4.7Ghz
    Memory (part number)Corsair Dominator Platinum SE Torque (4x8GB) / 3200MHz
    Graphics Card #1ASUS ROG Strix RTX 2080 Ti - White Edition
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 970 EVO Plus series SSD 500GB M.2
    Storage #2Samsung SSD 750 EVO 250GB
    CPU CoolerASUS ROG Ryujin 240mm
    CaseFractal Design Define R6 White
    Power SupplyCorsair RM850x
    Keyboard MSI GK80
    Mouse Microsoft Pro IntelliMouse
    Headset Corsair Gaming Virtuoso RGB White
    Mouse Pad ASUS ROG Sheath - XXL
    Headset/Speakers Logitech Z-5500 THX-Certified 5.1
    OS Win 10 64bit
    Network RouterAsus RT-AC86U
    Dec 2016
    22
    Quote Originally Posted by Al_Jourgensen View Post
    Hello
    think you find it on the included cd.
    New ROGer Array
    Mar 2014
    1
    Think your find this monitor is not 3D
    Administrator Array MasterC@ASUS's Avatar
    Aug 2014
    110
    1,565
    Hello
    ROG Swift PG278QR supports 3D fine.
    Can you provide more info about your setup?
    You graphics card? Driver version?
    Windows build?
    Are you using an HDMI cable? You need to use DisplayPort (HDMI only supports 60Hz refresh rate and you need 120Hz).
