Results 1 to 2 of 2
    ROG Enthusiast Array
    Jan 2017
    38
    noob - Zenith Extreme M.2 installation
    Hi
    Having a difficult time with something that should be so simple. Trying to install a M.2 drive in my new Zenith Extreme mobo but to do so I have to first unscrew 3 tiny Phillips screws on the cover (see attached).
    The problem is that they are screwed EXTREMELY tight! I am literally losing skin on my fingers trying to loosen!
    And yes I am turning counter clockwise!!
    I am using tiny jeweller's screwdriver so the issue may be I simple can't generate enough torque to loosen.
    Can anyone tell me which EXACT screwdriver I should be using?
    ROG Guru: White Belt Array Dimitrios1971 PC Specs
    Laptop (Model)GX700VO
    MotherboardASUS ROG ZENITH EXTREME ALPHA
    ProcessorAMD Ryzen Threadripper 2950X
    Memory (part number)F4-4000C18Q2-64TZR (3333MHz)
    Graphics Card #1ROG Strix GeForce® GTX 1080 Ti OC-Edition
    Graphics Card #2ROG Strix GeForce® GTX 1080 Ti OC-Edition
    MonitorROG Swift PG348Q Gaming
    Storage #13 x Samsung SSD NVMe 960 PRO 1TB Raid0
    Storage #22 x HGST Ultrastar He8 Raid_1
    CPU CoolerCOOLER MASTER MasterLiquid ML360 RGB TR4 Edition
    CaseCOOLERMASTER COSMOS C700P
    Power SupplyASUS ROG THOR 1200P
    Keyboard ROG Strix Flare RGB
    Mouse ROG Strix Evolve, ROG Gladius II
    Headset ROG Strix Fusion 700 & ROG Strix Wireless
    Mouse Pad ROG Sheath
    Headset/Speakers ROG Strix Magnus
    OS Win10_x64
    Network RouterFRITZ!Box 6590 Cable
    Accessory #1 BW-16D1H-U PRO
    Accessory #2 OC Panel I
    Accessory #3 ROG Headset Holder
    Dimitrios1971's Avatar
    Apr 2015
    19
    92
    for example...
Tags for this Thread
