Results 1 to 4 of 4
    New ROGer Array
    Dec 2017
    1
    Exclamation Gl553 Laptop Heating Issue Please help
    Hello i recently yought an ROG Gl553 laptop whenever i run any game such as gta5 , sniper elite , sniper ghost warrior my laptop heats up to 75-80C even when graphics set to medium and vsync off so i just wanted to ask if this is normal as i have seen other laptops with the same specs they do not heat this much. My room temp is around 30-34C. I havent used gammming laptops much so just a silly concern if u can help me. I have attached the results of the ROG control centre while playing a game.
    While my System is IDLE
    While Gamming
    Thank you in advance
    ROG Enthusiast Array Exalanoto PC Specs
    Exalanoto PC Specs
    MotherboardMaximus X hero Z370
    ProcessorI7 8700k
    Memory (part number)F4-3600C16D-16GTZR
    Graphics Card #1Asus Geforce 1080ti OC Gaming
    Storage #1Samsung NWME 960 Evo 250gb
    Storage #2Corsair 500GB SSD
    Power SupplyEVGA G3 850w
    Mouse Razer Naga
    Headset Logitech G933
    Mouse Pad Steelseries
    Headset/Speakers Creative THX
    OS Windows 10 64B pro
    Dec 2017
    63
    Is there any software with gaming mode? like, something to boost fans while gaming? i guess most gaming lappies have that function, atleast the once i have tried.
    When gaming, this should be turned ON. Also, youre room temp is a bit high, so i highly recomend you buying one of those fan stations to have youre laptop on, this will help cooling the computer.
    im not used to gaming lappies, but the temp seems a bit high to me atleast.
    ROG Member Array
    Dec 2017
    7
    Lightbulb
    Mine's gets around 65-70 C°, that's good when it doesn't go beyond that line (red numbers warn you about that).
    A external fan could help you (I wanna get one so internal fans doesn't force themselves too much), as well as manually telling Gaming Center to use 90-100% of the fans while playing hardcore games.
    Hope that helps
    Regards, Wolney Sandoval.
    ROG Guru: White Belt Array mmohamed2's Avatar
    Jul 2017
    97
    Same here , between 80 85C
    I USE 100% OF FAN SPEED
    NO OVERCLOCK
Tags for this Thread
