Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
    ROG Member Array
    Sep 2017
    15
    Claymore - CAPS lock LED not working
    ROG Claymore - not sure if hardware or software fault but the CAPS lock LED is not working.
    Any suggestions? Latest firmware and software.
    Kind Regards,
    Santo
    Administrator Array MasterC@ASUS's Avatar
    Aug 2014
    110
    1,543
    Hi Santo,
    Sounds like a hardware issue, it's working fine on my end. Aura software does not affect the Caps Lock LED, I'd suggest RMA.
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,857
    Mine has never worked.
    ROG Guru: Yellow Belt Array
    Jul 2017
    172
    Quote Originally Posted by MasterC@ASUS View Post
    Hi Santo,
    Well it does for me.
    If the Claymore is synced via Aura AND if i turn the lighting off, it also turn off the caps lock led and the ver num led...
    Sent from my XT1562 using Tapatalk
    ROG Member Array
    Sep 2017
    15
    Not Hardware
    Not Hardware - If i undo the sync in Aura then the caps lock LED works.
    Jul 2017
    172
    Quote Originally Posted by santoitaliano View Post
    They should also work if synced but not on all modes (in rainbow they don't but in color cycle they do if i remember well)
  7. #7
    Aug 2014
    110
    1,543
    When the Claymore is synced to other components (including the motherboard) using Aura Sync, the CAPS Lock LED works as it should for all the standard modes (Static, Breathing, and Color Cycle). People using Aura Sync with peripherals only don't need to worry.
    However, when the exclusive modes (Rainbow, Comet, etc.) are activated then we have confirmed there is a bug. These modes disable the CAPS Lock LED (this affects the LED only, functionality of the key is fine). It's kind of a weird case, but we're on it. Thanks for bringing it to our attention!
  8. #8
    Aug 2014
    110
    1,543
    Quote Originally Posted by JustinThyme View Post
    Perhaps you had one of those Aura modes enabled all this time? Sorry about that. Can you verify?
  9. #9
    Jul 2017
    172
    When the Claymore is synced to other components (including the motherboard) using Aura Sync, the CAPS Lock LED works as it should for all the standard modes (Static, Breathing, and Color Cycle). People using Aura Sync with peripherals don't need to worry.
    The verr num also is broken btw and the 2 additional leds under the space bar are turned off. Also the rog eye is turned off in these modes.
    I would also add that the overall lighting intensity of the keyboard comparing others devices (gladius 2 and mobo) is way to low while syncing via aura.
    Could this be also fixed?
    Thanks
  10. #10
    Aug 2014
    110
    1,543
    Quote Originally Posted by namoi View Post
    Thanks
    Thanks for the feedback, we'll look into it.
