i7 8700 non K voltage help
Thauner
Hello forum,
Just finished my first build ever, using it for producing music.
I have the non k 8700 with a z370 strix-I gaming motherboard.
XMP is enabled because of my ram that is 3200mhz (16gb), but all other things is set to auto/stock.
Cpu core ratio is on auto.
I have also set Asus MCE to disable.
When i run my DAW music software wich will be the typical max load for me, I get very high voltage numbers.
VCORE: 1392v (have seen it over 1400 also)
VID: 1515v
is this normal?
how do i fix this?
Running on the latest (not beta) version of bios
Thanks in advance 🙂
0 REPLIES 0
