Results 1 to 10 of 10
    ROG Guru: White Belt Array Jbonnett PC Specs
    Jbonnett PC Specs
    MotherboardRampage V Extreme
    Processori7 5960X
    Memory (part number)Corsair Dominator Platinum 32GB (CMD16GX4M2B3000C15)
    Graphics Card #1EVGA Titan X SC
    Graphics Card #2EVGA Titan X SC
    Storage #1Samsung 950 Pro 512GB
    Storage #2Samsung 850 Pro 512GB
    CPU CoolerCorsair H100i
    CaseNZXT S340
    Power SupplyCorsair H1000i
    OS Windows 10 Pro
    Jbonnett's Avatar
    Oct 2015
    109
    CPU and Memory usage extremely high
    Hi All,
    Can you help me figure out what is happening here?
    I don't understand how these particular programs can use 8 cores at 4.6GHz and 32GB of RAM.
    If I close Gamefirst VI I still get the same problem. When I close Both Gamefirst and Call of Duty: WWII I'm still using 80% of my CPU and 90% RAM.
    I don't even think the RAM is reporting correctly from this screenshot, though it is still extremely sluggish:
    Memory leak perhaps? Although that doesn't explain the unusually high CPU usage.
    Thanks,
    Jamie
    ROG Guru: White Belt Array CODE MAXIMUS PC Specs
    MotherboardMAXIMUS IX CODE • BIOS 1009
    Processor7700K • 4.5GHz
    Memory (part number)Corsair Vengeance LPX • CMK16GX4M2B3600C18 ver4.31 • 3866MHz • 15-15-15-36-2CR
    Graphics Card #1ASUS STRIX 1080Ti OC
    Sound CardOnboard • SupremeFX S1220
    MonitorASUS ROG SWIFT PG279Q
    Storage #1Intel Optane 900P 480GB
    CPU Cooler2016 EKWB Supremacy EVO • Acetal + Nickel • Straight Distilled Water
    CaseCORSAIR AIR 540
    Power SupplyEVGA Supernova 850W P2
    Keyboard HyperX FPS Alloy TKL
    Mouse SteelSeries SENSEI 310
    Headset Coolermaster Masterpulse
    Mouse Pad SteelSeries QCK Limited
    Headset/Speakers 100W BLACKWEB ZULU 2.1 • Soundbar + 8" Sub • TOSLINK
    OS WIN 10 64bit
    Network RouterNETGEAR X4S • Gigabit fiber optic connection
    Accessory #1 3X Corsair Magnetic Levitation 140mm PWM case fans
    Accessory #2 2X Corsair Magnetic Levitation 120mm PWM radiator fans
    Accessory #3 APC XS 1000 • Backup
    CODE MAXIMUS's Avatar
    Mar 2017
    42
    123
    Wow that's alot of processes, maybe try Windows Resource Monitor or Sysinternals to pinpoint the culprit.
    Jbonnett PC Specs
    Processori7 5960X
    CaseNZXT S340
    OS Windows 10 Pro
    Jbonnett's Avatar
    Oct 2015
    109
    Quote Originally Posted by CODE MAXIMUS View Post
    Well it's happened twice this week, is there a way I can diagnose now that I'm not having the problem?
    CaseCORSAIR AIR 540
    OS WIN 10 64bit
    Mar 2017
    42
    123
Name:	Screenshot (26)_LI.jpg
    Jbonnett PC Specs
    Processori7 5960X
    CaseNZXT S340
    OS Windows 10 Pro
    Jbonnett's Avatar
    Oct 2015
    109
    But arn't they both real time programs? E.g. I can't diagnose after the fact...
    As it is intermittent and not happening this second so I can't do anything right now.
    So is there a way of doing it now? Not when the problem arises again.
    CaseCORSAIR AIR 540
    OS WIN 10 64bit
    Mar 2017
    42
    123
    Quote Originally Posted by Jbonnett View Post
    Remember when it happens, log time, check control panel>Security and Maintenance and note time when last maintance was performed, with all those processes and maintance running at the same time that could have been what is happening.
  7. #7
    Jbonnett PC Specs
    Processori7 5960X
    CaseNZXT S340
    OS Windows 10 Pro
    Jbonnett's Avatar
    Oct 2015
    109
    Maintenance was ran 50 mins ago. So it couldn't have been that.
  8. #8
  9. #9
    ROG Guru: White Belt Array Scorpion PC Specs
    Scorpion PC Specs
    MotherboardASUS Maximus XI Extreme
    Processori9-9900k @ 5.0GHz
    Memory (part number)G.SKILL TridentZ RGB Series 3600MHz 16GB F4-3600C16D-16GTZR
    Graphics Card #1EVGA Nvidia GeForce RTX 3080 FTW3 On Air
    MonitorAcer Predator XB271HU 27" 1440P G-Sync
    Storage #1Samsung 970 EVO Plus 500GB NVME (OS)
    Storage #2Samsung 970 EVO Plus 2TB NVME (Games)
    CPU CoolerCorsair iCUE H115i ELITE CAPELLIX
    CaseCorsair 750D Airflow Edition Full Tower
    Power SupplyCorsair AX1200i PSU
    Keyboard Logitech G19s
    Mouse Logitech G502
    OS Windows 10 Pro x64
    Network RouterASUS RT-AX88U
    Mar 2012
    11
    120
    Do a fresh load of Windows, with latest drivers and Windows Updates, most def a software issue...
    Intel i9-9900k @ 5000Mhz on iCUE H115i ELITE CAPELLIX
    ASUS Maximus XI Extreme BIOS 1402
    G.SKILL TridentZ RGB 16GB @ 3333MHz 2x8GB 14-14-14-36-1T
    Onboard SupremeFX
    Samsung 970 EVO Plus 500GB - SSD (Games): Samsung 970 EVO Plus 2TB
    Corsair AX1200i
    Coorsair Obsidian 750D Air
    Logitech G19s - Mouse: Logitech G502
    Windows 10 Pro x64-bit
    Acer Predator XB271HU 27" 144/165Hz G-Sync IPS 1440P
  10. #10
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,854
    Looks like for starters your AV is in an active scan while playing a game.
    I dont use superfetch and prefetch on SSDs. Moot point....
