Rampage VI extreme M.2 Question
LiquidTyphon
I installed a Samsung 2TB 960 pro on the regular M2 slot, I also installed a 500GB 950pro in the ROG DIMM.2 Socket.
For some reason my mobo is not recognizing it in windows or Bios.
Does anyone have some solution?
5 REPLIES 5
JustinThyme
Not recognizing which?
Both?
Both?
Dimm.2 is not working is is in slot one facing the Ram.
my M2 insert on the board is working.
https://imgur.com/a/wOtEv
69796
https://imgur.com/yi67PKp
69803
JustinThyme
Check your BIOS settings that its not set up to run that port in VROC.
Advanced>Advanced CPU Storage Configuration.
PCIE8_4, DIMM.2 and U2 should be set to disabled
Also check your settings for PCH storage still under adanced to that its set to AHCI
Advanced Onboard devices M2 should be set to PCH unless you intend on running Intel drives in VROC. While you are there make shure the tab right under it for PCIEx8_4 is set to auto.
I am still having same issue here
Is there a magic trick to get this working?
I have a m.2 in the ram side of Dimm.2 as well but not being recognised
