Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 39
    ROG Enthusiast Array VixusFoxy's Avatar
    Apr 2017
    34
    BUYER BEWARE: ASUS Zephyrus batteries are a HAZARD.
    Administrator Array MasterC@ROG's Avatar
    Aug 2014
    208
    2,233
    Does the battery life of the the laptop correspond to the what the software indicates? How long does the battery last now (after a full charge)?
    Apr 2017
    34
    Quote Originally Posted by MasterC@ASUS View Post
    This is the Windows battery management output.
    The battery life of the laptop corresponds with those readouts which is what prompted me to analyze it to begine with.
    I have just enough time to run with my laptop from the living room to the bedroom and quickly plug it in again.
    Which is about a minute or two, tops.
    Aug 2014
    208
    2,233
    Please send it in for RMA, the laptop certainly shouldn't last for a couple of minutes.
    Apr 2017
    34
    So I decided to look it on for a few more weeks and I've noticed that my keyboard is bulging.
    I'm very curious whether the battery is situated under the keyboard right now.
    Aug 2014
    208
    2,233
    Really should have somebody look at it soon. Which GX laptop do you have? Zephyrus?
  7. #7
    Apr 2017
    34
  8. #8
    Aug 2014
    208
    2,233
    Ahhh! Doesn't look good... That is indeed where the battery is. If there are any issues getting it RMA'd let us know.
  9. #9
    Apr 2017
    34
    Hiya MasterC,
    I'm currently underway to the store. It's a 2 hour train journey so I figured I might as well post a status update.
    Called the retailer (Alternate) and they told me that I could either send the machine back by mail or actually go to the store and turn it over there with the ability to either get a replacement or a loaner for the time being.
    However, what I'm afraid of is that, when the machine comes back from the service center, that the keyboard will still be warped, and that the audio distortion bug that has been plaguing other users will still be present despite the FW / SW updates.
    Anyway, we'll see how it all turns out. I'm just admittedly a bit salty about my 3300 euro laptop giving me more trouble than any other machine I've bought before.
    Kind regards,
    Vix.
  10. #10
    Aug 2014
    208
    2,233
    Quote Originally Posted by VixusFoxy View Post
    Hiya MasterC,
    Anyway, we'll see how it all turns out. I'm just admittedly a bit salty about my 3300 euro laptop giving me more trouble than any other machine I've bought before and at this time am even silently hoping that it is beyond saving so I can have my money back and invest it in another device, perhaps even with a bigger screen.
    Kind regards,
    Vix.
    Sorry for the inconvenience caused. This is the first time I've heard of this issue, and I have reported it to the manager responsible for the Zephyrus. Please private message me your RMA number when you get it, we will make sure the keyboard isn't warped and check for audio distortion as well.
