Results 1 to 8 of 8
12-25-2017 12:27 PM #1
samuel9521 PC Specs Motherboard Asus ROG Strix Z370-F Gaming Processor Intel Core i5-8600K @5GHz - Cache @4,5GHz Memory (part number) G.Skill Trident Z RGB 2x8GB @3866MHz 15-16-16-35 Graphics Card #1 EVGA GeForce RTX 2070 XC ULTRA @2GHz - VRAM @16GHz Monitor AOC Agon AG241QX 1440p 144Hz 1ms Storage #1 Samsung SSD 960 PRO 512GB Storage #2 Samsung SSD 960 PRO 500GB & WD Blue 3TB CPU Cooler Cooler Master MasterLiquid Pro 240 Case Corsair Crystal 460X Power Supply Evga Supernova 650 G3 Keyboard Cooler Master MasterKeys Lite L Combo Mouse Logitech G502 Hero SE Headset Logitech G633 Mouse Pad HyperX 900x420mm Headset/Speakers Logitech Z150 OS Windows 10 Pro 64bit Accessory #1 Logitech F710 Controller
- Join Date
- Aug 2017
- Reputation
- 10
- Posts
- 15
Problem with Strix Z370-F and i5-8600K
Hi All,
I have a weird problem with my system:
A few days ago I assembled my new mobo and cpu (Strix Z370-F and Intel Core i5-8600K) in my pc, after uninstalling some drivers and softwares for the Strix Z270-F and i7-7700K system I had before. The pc booted up normally, so I installed new softwares and drivers for these new components. At that point, everything worked properly.
After that, I decided to try overclocking the cpu: I tested it @5 GHz and it was stable with the core voltage at 1.3V, then I started pushing up the cpu to 5.2GHz at 1.39V but the system was unstable. So I slowed it down to 5.1GHz at 1.375V but it was unstable too.
After this last crash, the pc started crashing in loop on boot with a blue screen (everytime the error was different), so I loaded the default settings in the bios, but nothing changed.
I tried changing some settings in the bios like speedstep, multicore enhancement, turbo mode etc., and the only thing I noticed was that, with all of these settings disabled, windows managed to boot and work for some seconds, but it was unusable.
Then I changed the number of active cores, and discovered that the system is perfectly stable with only 2 active cores (I managed to overclock them @5.2GHz with the cache @4.5GHz at 1.33V, and it doesn't crash), but from 3 to 6 active cores windows crashes in loop on boot. I also tried make it boot in safe mode with default settings in the bios, but the system was unstable too.
I tried disassembling and rebuilding the whole pc, changed the ram and verified that all the cables were well-linked, but nothing changed.
Now I don't know what to do, and I hope you can help me.
Thanks in advance.Last edited by samuel9521; 12-27-2017 at 02:35 PM.
12-25-2017 01:10 PM #2
Guliganx PC Specs Laptop (Model) MSI GT 73E VR 7RE Titan Motherboard Asus Strix Z370 F Gaming Processor Intel 8700K Memory (part number) 32Gb Corsair 3200Mhz Graphics Card #1 1080 Ti OC Asus Strix Monitor Asus 34 pg348q Storage #1 M.2 NVME Samsung 960 250Gb Storage #2 SanDisk Ultra II 960GB CPU Cooler Corsair H115i Case Cosmos 2 Power Supply Striker 1100W Keyboard Corsair Lux 70 Mouse Razer Mamba Headset Logitech G930 Headset/Speakers SoundBlasterX Katana OS W10
- Join Date
- Oct 2017
- Reputation
- 10
- Posts
- 2
Similar issues here
Exactly the same , coming from Strix Z270-F and i7-7700K system I had before. i assembled my new mobo and cpu (Strix Z370-F and Intel Core i7-8700K), all was Ok , for 2 weeks then whilst playing I had a crash, frozen game, then start my nightmare Blue Screen of death every time... no time even to restart W10 again...my set up is:
I7 8700k
Strix Z370 F-Gaming
Corsair H115i
32gb Ram Corsair 3200Mhz
Evo960 m.2 - 256gb
1tb SSD + 3tb HD
1080 ti Asus Strix
Bios updated, tried cleaning up memory, disabling XMP , enabling etc... removing graphic card and running from mobo IGC, and nothing... even without drives , just W10 Pendrive boot, when try to load boom.. bsod.
I have ordered Hero X , hope no issues with this MOBO if issue persist... I ll send this back.
12-26-2017 11:11 AM #3
- Join Date
- Aug 2017
- Reputation
- 10
- Posts
- 15
I've just noticed that when I turn on the pc after putting it in current, it turns on and instantly turns off for two times, then it boots up. That makes me thinking it could be an alimentation problem due to a bios bug.
12-27-2017 09:41 AM #4
- Join Date
- Oct 2017
- Reputation
- 10
- Posts
- 2
Defo
I have ▷ Aerocool Strike-X 1100W '80 Plus, more than enough... it s defo a bug in BIOS...
12-27-2017 11:42 AM #5
Menthol PC Specs Motherboard M 10 Apex / XI gene Processor 8700K / 9900K Memory (part number) 2x8 Gskill Trident Z 4266/2x2x8 Gskill Trident Z 4500 Graphics Card #1 RTX 2080ti / GTX 1060 Sound Card SoundBlaster Ae5 / Onboard Monitor BENQ 32" 4K Storage #1 Intel 900p 480GB/Samsung 960 Pro 1TB Storage #2 Intel 750 1.2TB/Plextor 1 TB 2X 950 Pro CPU Cooler Corsair H150i AIO / H1110i Case Corsair 740 ? Lian Li Air Power Supply Corsair AX 1200i / AX 1200i Keyboard Corsair Mouse ASUS Strix Headset HyperX Cloud Alpha Mouse Pad ASUS Headset/Speakers Logitech Z906 OS 10 X64 Pro Network Router Verizon Fios Accessory #1 Intel Wifi BT pcie card Accessory #2 Red Bull Accessory #3 English Breakfast Tea
- Join Date
- Jan 2012
- Reputation
- 241
- Posts
- 4,548
Just a guess but 5.2GHZ is a very high overclock and not very many CPU's can run at that speed, even one blue screen can corrupt the OS beyond repair, have you tried booting to your OS media at default settings to see if you can repair the OS
After a system crash or hard reset, turning off power supply a dual boot is normal
12-27-2017 02:19 PM #6
- Join Date
- Aug 2017
- Reputation
- 10
- Posts
- 15
Yes, I tried booting at default settings from the pen drive in which I put the OS, but nothing has changed, it just continues to crash in loop on boot before showing anything.
Edit: I tried booting from the pen drive with only 2 active cores, and it worked, but when it tries to auto repair the OS, it says that it can't.Last edited by samuel9521; 12-27-2017 at 02:35 PM.
12-29-2017 09:59 PM #7
- Join Date
- Aug 2017
- Reputation
- 10
- Posts
- 15
SOLVED (maybe)
Ok I think I solved the problem, I replaced the cpu with another 8600k and now the pc works with all the 6 cores. I won't overclock it for a few days in order to understand whether the problem was the cpu or the mobo.
12-30-2017 01:07 AM #8
- Join Date
- Jan 2012
- Reputation
- 241
- Posts
- 4,548
samuel19521, good the here you got this resolved, it sure seems to be quite a few bad CPU's the last gen. or 2
