Results 1 to 3 of 3
Thread: Max X Hero - NIC Stops Working
12-26-2017 12:26 AM #1
- Join Date
- Aug 2016
- Reputation
- 10
- Posts
- 2
Hey Folks,
Bit of an odd one here, i can't figure it out and i'm halfway to RMA'ing the motherboard but hope it's a software issue..
basically, i will start mining with my computer and let it run while I sleep (it's my gaming rig) and at random points the nic will start resetting itself.
To sum it up, i get these errors in my event viewer OVER and OVER until i reboot.:
The network interface "Intel(R) Ethernet Connection (2) I219-V" has begun resetting. There will be a momentary disruption in network connectivity while the hardware resets. Reason: The network driver detected that its hardware has stopped responding to commands. This network interface has reset 1 time(s) since it was last initialized.Intel(R) Ethernet Connection (2) I219-V
Network link is disconnected.Intel(R) Ethernet Connection (2) I219-V
Network link has been established at 1Gbps full duplex.
I installed the drivers from Asus' website...it's brand new install of Windows 10 pro, basically ~3 days old. I haven't tested to see if mining is what does it, but i also went through and disabled any and all power saving features for the NIC prior to even bothering to post here as well.
ANy guidance would be awesome!
12-26-2017 12:47 PM #2
Menthol PC Specs Motherboard M 10 Apex / XI gene Processor 8700K / 9900K Memory (part number) 2x8 Gskill Trident Z 4266/2x2x8 Gskill Trident Z 4500 Graphics Card #1 RTX 2080ti / GTX 1060 Sound Card SoundBlaster Ae5 / Onboard Monitor BENQ 32" 4K Storage #1 Intel 900p 480GB/Samsung 960 Pro 1TB Storage #2 Intel 750 1.2TB/Plextor 1 TB 2X 950 Pro CPU Cooler Corsair H150i AIO / H1110i Case Corsair 740 ? Lian Li Air Power Supply Corsair AX 1200i / AX 1200i Keyboard Corsair Mouse ASUS Strix Headset HyperX Cloud Alpha Mouse Pad ASUS Headset/Speakers Logitech Z906 OS 10 X64 Pro Network Router Verizon Fios Accessory #1 Intel Wifi BT pcie card Accessory #2 Red Bull Accessory #3 English Breakfast Tea
- Join Date
- Jan 2012
- Reputation
- 241
- Posts
- 4,548
BlakeVA,
I have never mined but have no issues on my X Hero Wifi.
Have you tried uninstalling the NIC driver and using the Windows NIC driver?
Is your system overclocked in any way, including using XMP
Have you tried default bios settings
Is your blck at 100, some memory XMP setting changes the blck from 100 to 102, 103, 125 which can sometimes cause issues with NIC, USB etc.
What browser do you use, antivirus software,
have you tried making changes to the new gaming mode stuff included in the new Windows version, I don't know if that would affect mining, I just disable all of it including XBOX related stuff myself as it's only for Windows games
12-30-2017 05:30 PM #3
Deepcuts PC Specs Motherboard Asus Maximus X HERO BIOS 1901 Processor Intel i7 8700K @ 4.7Ghz 1.215V Memory (part number) CMR32GX4M4C3466C16 @ 3200Mhz 1.360V Graphics Card #1 Asus Strix GTX 1080Ti OC 11GB Sound Card Creative Omni 5.1 USB Monitor Dell 24' S2417DG Storage #1 Samsung EVO 960 nvme 500 GB Storage #2 Seagate NAS 8TBx2 CPU Cooler NZXT Kraken X62 Case Fractal Design Define R5 Black Power Supply Corsair AXi760 Keyboard Razer DeathStalker Chroma Mouse Razer Abyssus OS Windows 10 Network Router Mikrotik
- Join Date
- Jan 2014
- Reputation
- 13
- Posts
- 245
You can try increasing the DHCP max lease time.
Some users found that some routers will cause this behavior when renewing the lease.
I never experienced this issue tho.
http://www.tomshardware.co.uk/answer...isconnect.html
https://forums.guru3d.com/threads/dh...hourly.376456/
