Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 27
    New ROGer Array
    Nov 2015
    18
    Asus G751 switches to battery when playing intensive games
    Since several weeks ago I have a problem with my Asus G751. After returning from Tech service as the LED panel failed (Asus changed it at no cost as warranty), another problem appeared. When I try to load intensive GPU/CPU tasks like gaming, with the charger plugged to AC, the battery mode icon appear on screen, and act as if I just unplugged the charger/adaptor from AC. If I keep the computer low on resourcers (like surfing the internet, using Word, watching a movie...) that does not happen, and battery is at 99%.
    Seems that when the power demand goes up, the charger can't deliver the amps needed. Then, I need to power off the computer for several minutes to make the charger work again.
    Should I buy another charger? (I think it is a 230W one) or may be something related to a component inside the laptop? I do not have money to buy an expensive 230W charger just to see the same thing happens. Unfortunately, warranty has just expired
    Thank you!
    Harlock
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    351
    8,112
    I concur that sounds like a charger problem. Unfortunately you are correct that the best way to test it is to try another one. You might see if you can find a seller that has a return policy so you can send it back if something else is wrong.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    New ROGer Array
    Nov 2015
    18
    Road 6700
    Yes, seems it's the best option. Thank you
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,854
    I doint know about switching to battery but some do draw from the battery under heavy loads.
    Which G751 are we talking about? If its the JY then this behavior is perfectly normal as the brick cant keep up with the power demand of the CPU and GPU.
    xeromist PC Specs
    ProcessorAMD 2600X
    CPU CoolerWraith
    xeromist's Avatar
    Jul 2010
    351
    8,112
    Quote Originally Posted by JustinThyme View Post
    But does it actually display the battery icon when that happens?
    New ROGer Array
    Nov 2015
    18
    Vasari RIGBY
    It is the JY, yes, with a 980GTX and 3 hard disks (1 ssd, 2 spin) so it is power hungry. The problem is the battery icon appear, orange led turn off, and begin to draw power from the battery until it is depleted. If I leave the game and return to windows (or stop a render of After Effects for example), brick does not begin to charge again, that is, orange charging led does not light. It is like the brick is dead. Also, if I touch the numeric keyboard, specially at 0 key, is very very hot. That behaviour did not show before sending the laptop to Asus for screen repair (it may be just a coincidence).
    If the problem is the power brick, where can I find a reliable seller with high quality power adapters? Seems the one that came from ASUS is not up to the task (and I really do not game or render a lot, just once in a month really).
    What really worries me is the power plug (it is very hot when the switch to battery happens) and the numeric keyboard hot point. It may show that is not really the power brick, and something inside is not working ok. The problem is I have to order to china or EEUU, I did not find any seller of a 230W in Europe.
  7. #7
    xeromist PC Specs
    ProcessorAMD 2600X
    CPU CoolerWraith
    xeromist's Avatar
    Jul 2010
    351
    8,112
    So the same power brick did not have the same problem before the screen replacement and presumably it stayed in your possession? That along with the hot spot do cast some doubt on the issue as purely a problem with the brick. However I'm not sure there's a better way to confirm that.
  8. #8
    New ROGer Array
    Nov 2015
    18
    Quote Originally Posted by xeromist View Post
    I sent the power brick to asus alongside the laptop... never thought it could be another brick really. For now, I am avoiding 3D gaming (only play emus and FTL:Faster Than Light) and do basic things like browsing and office things. Strangely, RAR compression at ultra level does not trigger the effect (and it gets CPU to 100%).
    The first time it happened I was playing Planetside 2, some days after I received the laptop.
  9. #9
    xeromist PC Specs
    ProcessorAMD 2600X
    CPU CoolerWraith
    xeromist's Avatar
    Jul 2010
    351
    8,112
    That's not surprising. The GPU would increase power usage significantly. And yeah it could be another brick. They aren't distinctive so it could have been mixed up.
  10. #10
    New ROGer Array
    Nov 2015
    18
    Well, I suppose I have no choice but to order another brick then, it's the best option I have now.
Tags for this Thread
