12-27-2017 04:06 AM - last edited on 03-06-2024 09:35 PM by ROGBot
12-31-2017 07:04 PM
01-01-2018 12:25 PM
01-01-2018 04:17 PM
Clintlgm wrote:
Yes these are gaming notebooks, really desktop replacements they are not really intended to be used on battery alone but to stay plugged most of the time and minimum use while on battery only. For better battery life you would probably want to look in the business line of computers in the 15" models or entertainment models still in the 15" lines, 17" models with high end CPU and GPU and large amounts of RAM are just not going to last long on battery only.
01-07-2018 07:31 AM
High powered CPU's and GPU's do have the ability to downclock and reduce their voltages by quite a bit when not overly stressed or used.
Asus should have integrated a higher capacity battery or offered the same model with higher battery and probably spent more time to optimize the system and adjust CPU and GPU clocks and voltages at idle and mild-usage scenarios to draw less power - or at the very least, give us voltage control over the CPU and GPU.
01-07-2018 07:21 PM
f.courtault wrote:
Hello,
Fully agree with you.
More if we look at HP Omen same kind of models, they provide Li-ion 8 cells 86 Wh.
Other complains I have, for the moment, regarding this model are:
- The lack of Thunderbolt 3 connectivity
- The M.2 SATA SSD and not a PCIe/NVMe one even if, it seems, this connectivity exists
- The single channel RAM instead of dual channel
Best Regards.
01-08-2018 11:26 AM
01-08-2018 11:56 AM
f.courtault wrote:
Hello everyone,
I am quite disappointed with the battery life of this machine.
On this machine, I have used VLC to see a mp4 movie and it lasts only about one hour !
Do you have the same experience on your side ?
Any way to get it longer ?
Looking at the specifications , the only info we have is that it contains a 4 Cells Polymer Battery but we don't have the capacity of those ones 😞
Best Regards.
