12-27-2017 07:46 AM - last edited on 03-06-2024 08:36 PM by ROGBot
12-30-2017 05:11 AM
12-30-2017 05:21 AM
12-30-2017 06:07 AM
bnea02 wrote:
Im happy for you as of all the bios updates and stuff. I get insane temps at 4GHz asus oc profile and have a similar system.
My main problem is that the volts ramp up to really high levels => high temps.
And Aura and OLEDpanel dont work anymore :-(, otherwise its all good and dandy.
BNEA02
12-30-2017 06:42 AM
12-30-2017 06:58 AM
bnea02 wrote:
Ill have to get back to you as im at work atm, but will post full specs...
06-23-2018 10:17 AM
GeekhomeGamer wrote:
Hi all :).
The following screenshot prove that TRripper 1950x can run stable @ 4.2 GHZ with 3600Mhz ram speed.
This config/settings successfull pass AIDA64 Stress test and Prime95 test.
Can someone tell me if this is normal or ( most probably) a bios bug ?.
considering people can't run even on stock ram speed and can't reach 4.x GHz this seems very strange...
I'm really happy with build but... i think this result is a bios bug.
Settings:
OC : manual
3600
x40
100
LLC1/2 : 4
RAM ( OC @ 3600 ) v 1.71xx >73xx ( 3200 1.2500 )
cpu v set to 1.22500 ( bios show core voltage to 1.242 @ 23"c ) cpu-z show 1.264 !!!!
AMD PBS > IOMMU ENABLED
amd PBS > Streaming store control > enabled
amd PBS ZEN COMMON > custom pstate throttling > DIsabled
Zenith Extreme ( actually 0804 - aura 1.0.13 )
AMD RyZEN Threadripper 1950x
I can choose from this two settings
( 4.206 v1.26.875 ) x42 ( don't use it not caus system stability but fear of a bios bug and damage
( 4.0 v1.22500 ) x40
G.Skill RGB TridentZ 4x8 3200 CL14 @ v 1.2500 ( ZTR ) ( 3600 CL14/T2 v1.73 > 74 / 75 stable )
I never see Cpu temps exceed 26/30C degrees even with SW Stress test.
Enermax stock Thermal paste ( i'm waiting for Conductonaut liquid metal 5 grams )
this settings full pass AIDA64 / prime95 / Cpu-z / Cinebench / 3DMark.
i don't run "nonsense" 24/48/96 Hours of le mans stress tests. my stability test runs for 4 hours max
running stress test Software + VLC MKV video at the sametime, if the test pass.. is more than enough for my taste.
Full Specs:
Cougar Conquer
Corsair AX1500i
G.Skill RGB TridentZ ( Version ZTR ) 4x8 3200 cl14
GIGABYTE GTX 1060 6GB ( rev 2.0 ) ( 2x Titan XP/ 1x Volta after Holidays )
Corsair HP500 512
Samsung 960 Pro 1TB
Samsung 850 pro 1TB
ForceGT 240
8 TB 7200/256MB
Corsair Lightning Pro Controller
4 RGB LED Stripes
Integrated 7" Case monitor Display for Temp Monitoring.
Additional rear fan suspended pointing to VRM and CPU AIO Liquid Cooling Pump.
Enermax TR4 360 AIO Liquid Cooling
