Results 1 to 5 of 5
    ROG Junior Member Array
    Nov 2017
    3
    [Trident Z] F4-4133C19D-16GTZSWC XMP
    Version 1003 2018/01/028.23 MBytes
    ROG MAXIMUS X HERO BIOS 1003
    Improve system performance.
    Improved DRAM compatibility
    Still broken on XMP profile :
    DDR4-4133 (PC4-33000)
    16GB (8GBx2)
    CL19-19-19-39
    1.35 Volt
    Can only reach DDR4-3200, can't post above.
    Work fine with same i7 8700k stock XMP enable on MB = Gigabyte Z370 AORUS Gaming 5 ...
    ROG Guru: Orange Belt Array bass junkie xl PC Specs
    MotherboardZ690 Asus Strix D4 x 2 Bios 1604
    ProcessorRIG #1 12900 Ks @ 5.4/5.1 ring @ 1.36v/ RIG #2 12900 K @ 5.2/4.9 Ring @ 1.37v
    Memory (part number)DDR4 32GB Royals @ 4133 c15 Gear 1 / RiG # 2 32GB Team Group X @ 4000 cl-15-15-15-35 @ 1.52v
    Graphics Card #1RTX Asus 3090 TI LC + 240mm @ 2000 mhz @0.950v
    Graphics Card #2RTX 3080 EVGA XC3 Ultra @ 1860 mhz @ 0.842v
    Graphics Card #3MSI Gtx 1080 Ti + 360m aio @ 2000 mhz + 300 mem
    Sound CardMotherboard Realtec , Driver 87.46
    MonitorAsus Xg27AQM 27" @270 hz / Asus PG279Q 27" @165 HZ / AOC AG251FZ2 1080P @240hz
    Storage #1XPG 2TB/Samsung 970 evo+ 500 Gb / 970 Evo 1TB x 2
    Storage #22 tb HDD x 4
    CPU CoolerArtic liquid freezer 420mm / Deep Cool Gamermaxx 360mm v2 / Kraken G12 s36 360mm
    CaseThermaltake View 71 full Glass
    Power SupplyEvga 1000w Platnuim / evga 750 w
    Keyboard Corsair K95 Platnuim RGB
    Mouse Corsair Night Sword RGB
    Headset Razer Kraken 7.1 chroma
    Mouse Pad Asus Sheeth Large
    Headset/Speakers Logitech Z-5500 THX 5.1
    OS Windows 10-21h1 x64 Pro
    bass junkie xl's Avatar
    Oct 2017
    43
    367
    Quote Originally Posted by Sil3nt View Post
    16GB (8GBx2)
    CL19-19-19-39
    1.35 Volt
    thats very odd man im on asus x hero bios 802
    i have g.skill rgb 16gb (2 x 8 gb ) 3000 mhz cl 14-14-14-34 1.35v xmp
    i have these manualy over clocked to
    4000 mhz cl 18-19-19-38 1.4v
    vciio = auto
    vcssa=auto
    12 hr prime 95 stable blend @ 90 % ram coverage
    12 asus rela bench
    24 hci mem test stable
    i can run 4133 19-19-19-39 @ 1.45v didnt run tests on them @ that speed as i was shocked to get 4000 stable and iwas happy there @ 4 k cl 18
    8700k delided @ 5 ghz all cores ht on
    no avx offset =0
    adaptive mode =1.33v ( 1.34 - 1.35v on heavy load )
    wjhats this new bios 1003 ?????????? should i not even try it ? or im scared to brake my 4000 mhz stable settings lol
    Administrator Array Silent Scone@ROG's Avatar
    Mar 2016
    233
    2,708
    Quote Originally Posted by bass junkie xl View Post
    vciio = auto
    vcssa=auto
    12 asus rela bench
    no avx offset =0
    No reason to flash if you're happy with the way things are.
    ROG Guru: Gold Belt Array Menthol PC Specs
    Menthol PC Specs
    MotherboardM 10 Apex / XI gene
    Processor8700K / 9900K
    Memory (part number)2x8 Gskill Trident Z 4266/2x2x8 Gskill Trident Z 4500
    Graphics Card #1RTX 2080ti / GTX 1060
    Sound CardSoundBlaster Ae5 / Onboard
    MonitorBENQ 32" 4K
    Storage #1Intel 900p 480GB/Samsung 960 Pro 1TB
    Storage #2Intel 750 1.2TB/Plextor 1 TB 2X 950 Pro
    CPU CoolerCorsair H150i AIO / H1110i
    CaseCorsair 740 ? Lian Li Air
    Power SupplyCorsair AX 1200i / AX 1200i
    Keyboard Corsair
    Mouse ASUS Strix
    Headset HyperX Cloud Alpha
    Mouse Pad ASUS
    Headset/Speakers Logitech Z906
    OS 10 X64 Pro
    Network RouterVerizon Fios
    Accessory #1 Intel Wifi BT pcie card
    Accessory #2 Red Bull
    Accessory #3 English Breakfast Tea
    Menthol's Avatar
    Jan 2012
    241
    4,548
    I checked Gskill's site and that kit is QVL for IX Apex and X Apex only so I wouldn't say anything is broken
    I have a 2x8 4133 cl19 RGB kit running at 4133 (QVL on IX Apex only) on my Hero Wifi with dram v 1.38, VCCIO 1.2v and VCSSA 1.2375 manually set in bios and a few other settings changed. I set XMP then manually set the voltages above
    I knew there would probably be some manual tuning required and I would probably have to settle for lower speed than XMP rated, there are just to many variables involved
    I don't think you can compare one manufacturers board to another even with the same CPU as they may use different training rules, apply different voltages etc.
    New ROGer Array
    Dec 2017
    1
    Same here with 0802,same ram but going 3800 all auto with xmp enabled
Tags for this Thread
