Results 1 to 3 of 3
01-03-2018 12:45 PM #1
Halil PC Specs Laptop (Model) ASUS ROG G751JT Motherboard Intel Lynx Point HM87, Intel Haswell Processor Mobile QuadCore Intel Core i7-4750HQ, 3000 MHz (30 x 100) Memory (part number) 24525 MB (DDR3-1600 DDR3 SDRAM) Graphics Card #1 NVIDIA GeForce GTX 970M (3 GB) Sound Card Realtek ALC668 @ Intel Lynx Point PCH - High Definition Audio Controller [C-2] Monitor LG Philips LP173WF4-SPD1 [17.3" LCD] Storage #1 HDD - 2000 GB, 7200 RPM Storage #2 SSD - 250 GB, Samsung 850 EVO Mouse Razer DeathAdder Chrome Headset SteelSeries Flux On-Ear Mouse Pad Razer Hard OS Windows® 10 Pro 64 Bit
- Join Date
- Oct 2015
- Reputation
- 10
- Posts
- 45
ASUS G751 Custom Cooling System Upgrade
i'd like to do updgrade my G751's cooling system. I mean changing cpu and gpu fan to G752's because of G752's Fan has dust release:
This is G751's Fan:
This is G752's fan:
I am have kinda advanced questions i know both fan is 5V and 4 pin can i fit G752's fan into G751's ? is this work without any issue ?
if Screw's places won't match can i just duct tape ?
01-03-2018 01:09 PM #2
Gps3dx PC Specs Laptop (Model) Current: G751JT | Retired: G55VW, G51JX Motherboard Inc M.2 slot Storage #1 Samsungs EVO 850 128GB Storage #2 1TB HGST Travelstar 7K1000 (HTS721010A9E630) CPU Cooler Mother Nature & Thermodynamics laws Mouse Logitech MX 518 Headset/Speakers Logitech T6060 OS Cleaned installed Windows 10 HOME x64 Accessory #1 Leap Motion
- Join Date
- Feb 2015
- Reputation
- 71
- Posts
- 785
I don't see the major difference.
please note that the G751's fans got at their exit a skew in the metalic framework and an addition of a plastic cover paste onto it.
The G752's fans does not seems to have such design, thus it won't sit as tightly as it should in the mono hole for the fans.
moreover the screws hole are NOT at the same area !
if you want to cool your device ~15-20 C less, perform the cooling mod as posted by few user before, me inc.
don't forget it will void your warranty.Asus G751JT
Samsung EVO 850 120GB + 1TB HDD 7200RPM
Cleaned installed Win 10 HOME
My Guides:
- ROG LAPTOPS: COMPLETE DRIVER LIST !
- How to install windows 8/8.1/10 on any UEFI supported laptop the PROPER way
- HOW TO (EASILY!) UPGRADE FROM WIN7 SP1/8.1 WITHOUT GOING THROUGH THE UPGRADE PROCESS ITSELF !
- HOW TO REMAP FN+KEY AND SPECIAL BUTTONS: "STEAM", "ROG" & "SHADOWPLAY"
- Win 10 x64: SETUP USB @SUPERSPEED, NO HANG-UPS! | ACCELERATES USB 3.0/2.0 TRANSFER RATE SPEED TWICE!
01-03-2018 02:15 PM #3
- Join Date
- Oct 2015
- Reputation
- 10
- Posts
- 45
thx for replying yea i will do that too about warranty i already opened case for repasting
Anyway i will do that (in your link) but i am thinking about dust if i open caee like that so i guess dust release fan kinda help but if anyone can tell the G752 Cooling stystem worth it is this really releasing dust ?
