Results 1 to 4 of 4
    ROG Enthusiast Array tunc8686 PC Specs
    tunc8686 PC Specs
    MotherboardAsus Rog Maximus X Hero
    Processor8700K @5Ghz
    Memory (part number)Corsair Dominator 32GB (4*8Gb) 3200Mhz
    Graphics Card #1Asus Rog Strix 1080Ti OC
    MonitorAsus VG248QE
    Storage #1Samsung 950Pro 512Gb
    Storage #2Samsung 850Pro 256Gb
    CPU CoolerEKWB Costum Cpu Block
    CaseThermaltake View 71
    Power SupplyEvga Supernova 1000P2
    Keyboard Steelseries 7G
    Mouse Steelseries Rival 700
    Headset Corsair Void Pro
    Mouse Pad Steelseries QMass
    OS Win10
    tunc8686's Avatar
    Sep 2014
    11
    60
    8700K after DELID 5,0Ghz Temperature ?
    i delided my 8700K and overclock 5,0Ghz 1,350V
    i did prime95 40 min and my temperature like tihs ?
    is it fine or ?
    and before delid cpuz bench test temperature
    and after delid cpuz bench test temperature
    i shared pics
    actually i dont have any idea for overclock setting and i did 5,0ghz with this video :
    https://www.youtube.com/watch?v=CoUtA7DKXhU i did 5,0ghz like this
    maybe someone help me for 5,1ghz or 5,2ghz ?
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba OCZ VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Mouse Razer Basilisk
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,357
    Hi tunc8686
    With an average of -20c, you did a very successful delid.
    Nice going, now you can try for 5.1GHz - 5.2GHz.
    tunc8686 PC Specs
    MonitorAsus VG248QE
    OS Win10
    tunc8686's Avatar
    Sep 2014
    11
    60
    Quote Originally Posted by Nate152 View Post
    Hi tunc8686
    i dont have any idea for overclocking :S
    i will try to my best
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,357
    All you need to do is increase the voltage and the cpu core ratio and keep an eye on temps, you should be able to go up to 1.45ishv after delidding. Being yours is a six core cpu, it might run a little warmer than my 4 core delidded 7700k at 5.2GHz.
    Set the AI Overclock Tuner to Manual
    Sync All Cores and Set the CPU Core Ratio to 51
    Set the CPU Core/Cache voltage to Manual
    Enter in 1.45v in the CPU Core Voltage Override
    In DiGi+
    Set LLC to level 5 or 6
    F10 and Enter to Save and Exit.
    If you pass the test which you should, try the CPU Core Ratio at 52, post your temps and if you pass at 5.2GHz with 1.45v. Once you find your max overclock you can switch to Adaptive Mode so the cpu speed and voltage throttle at idle. If the temp goes over 90c at anytime, stop the test.
    Here's Watchdogs 2 at 5.2GHz with 1.440v, with LLC to level 6 it jumps to 1.456v.
