01-10-2018 12:18 AM - last edited on 03-06-2024 09:33 PM by ROGBot
01-10-2018 12:29 PM
Jasipi wrote:
Returned an MG279Q due to back light bleed and upgraded to PG279Q thinking it would be better. It has worse back light bleed. Can't return to Umart because i cannot afford their 20% restocking fee again, and i've since heard the stories about these monitors and now fear i'll just get a monitor with even worse bleed. Also Umart doesn't seem to consider this very good grounds for return.
I've contacted Asus support about repair but i've got a feeling that i'm going to get ripped off somewhere down the line so i'm hoping some intelligent person here has figured out a way for a regular person like me to fix the issue (or at least minimize it) myself just in case i'm refused any help.
Thanks.
01-10-2018 10:37 PM
01-11-2018 09:51 AM
bass junkie xl wrote:
some one told me a trick wich lets you see back light bleed even better you open up a full black screen darken room to pitch black and take your cell phone and aim it at the middle oif the screen and turn flash off and in the picture it wil lhigh light the dark and light spots of the back light bleed @ 4 - 6 feet away
and to my suprise mine was bad on the cell phone .
01-11-2018 04:25 PM
01-11-2018 10:10 PM
Jasipi wrote:
The back light bleed i have is in the top right corner and is very noticeable to the naked eye on black screens. Less noticeable when colours are moving over it but when dark enough it is easy to spot. I can make it go away around the top edge if i press on the case in just the right way but there doesn't seem to be anything i can do to get rid of the bleed up the top right side.
It is definitely back light bleed. It is definitely noticeable. I don't believe it should be there.
01-13-2018 08:15 AM
01-13-2018 10:07 AM
