01-10-2018 01:07 PM - last edited on 03-06-2024 09:34 PM by ROGBot
01-10-2018 01:17 PM
01-10-2018 01:23 PM
lightknightrr wrote:
What are you using to cool the CPU?
01-10-2018 01:45 PM
01-10-2018 01:59 PM
Exalanoto wrote:
Does the cpu coolers pump have power connected?
And, how hard or loose did you tighten youre cooling block to the cpu?
01-10-2018 04:09 PM
jayleong wrote:
yes already connected
thumb screw.. never over tighten
01-11-2018 02:07 AM
Exalanoto wrote:
Can you hear the pump? or feel any vibration from it?
Menthol wrote:
Is the sata power cable from your cooler connected to a sata power cable from your power supply, the cable from cooler to fan header only reads the RPM of the pump the sata cable supplies power to pump and fans
01-10-2018 04:16 PM
01-11-2018 02:08 AM
01-10-2018 07:10 PM
