Rog rampage vi extreme + rog front base
tud_mattias
Hello, I need your advice/help. I did upgrade recently to rampage VI extreme and noticed I can't control fans speed anymore by front base. CPU fans and Case fans, both was tested on auto and PWM settings in BIOS. Other options works fine just can't contort fans speed.
Drivers was installed correctly, both Connect plus and Front Base. Did try older one and newest one. Windows 10 64bit fresh installation. Please advice.
Thanks
-Nax-
Hello, same problem here, is there a firmware/driver update for Asus rampage vi extreme full support ?
Asus Support replayed to me: Front Base is NOT supported in Rampage VI Extreme. Fan Xpert 4 also sucks. You cant change default speed, so there is no good way to control manually my PWM fan speed in my custom liquid loop.
If you have some good solution like software or good not too expensive fan control let me know please. (Sentry 3 is not good. already have it, it will do the job but led is flashing when low fan speed).
