Results 1 to 6 of 6
Thread: 8700K stock vs delid temps?
01-12-2018 12:51 AM #1
Zeroed85 PC Specs Motherboard Asus Maximus XI Hero Z390 Processor 8700K 5Ghz Memory (part number) Dominator Platinum RGB 32GB 3466Mhz Graphics Card #1 EVGA RTX 2080 Ti FTW3 Sound Card SoundBlaster X AE-5 Monitor Asus ROG PG349Q 34" CPU Cooler Custom cooling Case Phanteks Eclipse P600S Power Supply Seasonic Prime 1300W Keyboard Corsair K70 MK.2 SE Mouse Corsair M65 Elite OS Win 10 64 1909
- Join Date
- Jun 2017
- Reputation
- 10
- Posts
- 121
I'm looking for some comparison/data for the 8700K delidded vs stock. Are there any compilation threads or good articles that do specific comparisons? Is it generally accepted that the stock chips get considerably high temperatures when pushing through the stock 4.7Ghz? I would really just like a more informed indication of what sort temps the stock chips are seeing when overclocked and even at at stock frequencies for high load and gaming temps to make a better decision whether investing in a delidded chip is for me. Cheers.
01-12-2018 03:06 AM #2
Menthol PC Specs Motherboard M 10 Apex / XI gene Processor 8700K / 9900K Memory (part number) 2x8 Gskill Trident Z 4266/2x2x8 Gskill Trident Z 4500 Graphics Card #1 RTX 2080ti / GTX 1060 Sound Card SoundBlaster Ae5 / Onboard Monitor BENQ 32" 4K Storage #1 Intel 900p 480GB/Samsung 960 Pro 1TB Storage #2 Intel 750 1.2TB/Plextor 1 TB 2X 950 Pro CPU Cooler Corsair H150i AIO / H1110i Case Corsair 740 ? Lian Li Air Power Supply Corsair AX 1200i / AX 1200i Keyboard Corsair Mouse ASUS Strix Headset HyperX Cloud Alpha Mouse Pad ASUS Headset/Speakers Logitech Z906 OS 10 X64 Pro Network Router Verizon Fios Accessory #1 Intel Wifi BT pcie card Accessory #2 Red Bull Accessory #3 English Breakfast Tea
- Join Date
- Jan 2012
- Reputation
- 241
- Posts
- 4,548
You can find detailed temperature comparisons by googling, it can be 10 to 20 degrees difference, every setup is different so you can find numbers that justify anything you want, only your results mater, your choice in cooling will make a big difference
One of the reasons I delid is with the lower temps I can lower the speed of all the fans in my case not only the ones on the cooler and have a much more enjoyable experience
I have found the 8700K to be so quick at default speed that it is difficult to tell any difference when OCed except benchmark numbers
01-12-2018 08:52 AM #3
Deepcuts PC Specs Motherboard Asus Maximus X HERO BIOS 1901 Processor Intel i7 8700K @ 4.7Ghz 1.215V Memory (part number) CMR32GX4M4C3466C16 @ 3200Mhz 1.360V Graphics Card #1 Asus Strix GTX 1080Ti OC 11GB Sound Card Creative Omni 5.1 USB Monitor Dell 24' S2417DG Storage #1 Samsung EVO 960 nvme 500 GB Storage #2 Seagate NAS 8TBx2 CPU Cooler NZXT Kraken X62 Case Fractal Design Define R5 Black Power Supply Corsair AXi760 Keyboard Razer DeathStalker Chroma Mouse Razer Abyssus OS Windows 10 Network Router Mikrotik
- Join Date
- Jan 2014
- Reputation
- 13
- Posts
- 245
4.7 is not stock
I just run all cores at 4.7 with lower fan speeds and call it a day. A less noisy day. Max 69-70 Celsius load (no delid)Last edited by Deepcuts; 01-12-2018 at 08:55 AM.
01-12-2018 09:15 AM #4
- Join Date
- Jun 2017
- Reputation
- 10
- Posts
- 121
It's the stock boost... Is the 70C a benchmark load? What are your gaming temps at 4.7 and what voltage? So do the temps really ramp up with the 8700K at a certain voltage or clock speed or both? I thought there was some hype around the chip running undesirably hot even at the stock 4.7 but it appears to be not until you run them at 5Ghz+ that delidding becomes more important..
01-12-2018 06:00 PM #5
- Join Date
- Jan 2014
- Reputation
- 13
- Posts
- 245
4.7Ghz is boost on only one core. What Asus does with MCE is called overclocking
In my setup, voltage for 4.7Ghz is 1.180V.
I get small spikes to 69-70 Celsius while doing long encodes with Handbrake, but the cores stay at ~60-65 Celsius for the most part.
In demanding games, I would say the same temperatures. Maybe a couple of deg. less. Because even tho CPU won't be hammered the same, the GPU will. Thus increased temps.
I tried going above but at least for me, the increased temperatures and noise levels are not worth it.
I keep all my Noctua case fans at ~700-800 rpm no matter the temperatures and my two Industrial Noctua fans for Kraken X62 at max 1000 rpm. All 6 fans 140mm.
Under load I get max 30 Decibels measured just outside the case (intake holes)
01-12-2018 09:44 PM #6
tunc8686 PC Specs Motherboard Asus Rog Maximus X Hero Processor 8700K @5Ghz Memory (part number) Corsair Dominator 32GB (4*8Gb) 3200Mhz Graphics Card #1 Asus Rog Strix 1080Ti OC Monitor Asus VG248QE Storage #1 Samsung 950Pro 512Gb Storage #2 Samsung 850Pro 256Gb CPU Cooler EKWB Costum Cpu Block Case Thermaltake View 71 Power Supply Evga Supernova 1000P2 Keyboard Steelseries 7G Mouse Steelseries Rival 700 Headset Corsair Void Pro Mouse Pad Steelseries QMass OS Win10
- Join Date
- Sep 2014
- Reputation
- 11
- Posts
- 63
