Aura & LiveDash: they do not work together
aged_osprey
Hello everybody,
I have a problem with my brand new Rampage VI Extreme with Aura and LiveDash software.
If both are installed, I can either use only the function of LiveDash or that of Aura, both will not work together!
I would like to show the CPU clock rate in LiveDash and use the temperature function in Aura.
Does anyone have any advice or can help?
Many thanks in advance
BIOS: 1004
Aura: 1.05.28
LiveDash: 1.00.06
WIN10 PRO 64
14 REPLIES 14
shadowfax25
I have somewhat different problem as my live dash doesn't even start on Prime x299-deluxe after installing Aura 1.05.28:o
AkaNe0
You can try to install the 1.01.07 Livedash version that fix the conflict between AURA and Livedash functionality. I have it on my test bench, and both are working fine together. Please give it a try.
And don't forget, Keep pushing it !
First Thx for helping 🙂
but it does not work
I first uninstalled aura and livedash
then I used the aura cleaner
then I have the computer completely de-energized
then i install aura 1.05.28 (i also try 1.05.32) as admin -> reboot -> aura works
then i install livedash 1.01.07 -> as admin -> reboot -> aura works with smart settings, livedash run into the taskmanager but i have no open livedash window for settings
70576
On Prime X299 Delux they also do not work together.
I tested version 1.01.04 and 1.01.07 with Aura 1.05.28.
AkaNe0
Thanks for trying.
Question, did you do the EC firmware update with "AURA + LiveDash OLED" tool available on the Utilities page of both model?
Please, also try to installed AI Suite.
AkaNe@Asus wrote:
Thanks for trying.
yes, here I have received the message that the latest version is installed
AISuite version 3.00.10 is now installed and actually starts LiveDash, but I get a CPU clock of 44297 Mhz in LiveDash
now it works
- deinstall AiSuite
- deinstall Aura
- deinstall Livedash
- cleaner for AiSuite
- cleaner for Aura
- switch off Computer
- switch off power for 2 minutes
- install AiSuite 3.00.13
- reboot
- install Aura 1.05.32
- reboot
- install LiveDash 1.01.07
- reboot
Check AiSuite -> ok
Check Aura -> Smart -> ok
Check Livedash -> large CPU Clock -> ok
now i am happy and many thanks for helping 🙂
greats aged_osprey
aged_osprey wrote:
now it works
- deinstall AiSuite
- deinstall Aura
- cleaner for Aura
- reboot
- reboot
- reboot
Check AiSuite -> ok
greats aged_osprey
Thanks for reporting. I am glad now everything works.
For the ones that have trouble between AURA and livedash, please do the following:
-> Install latest AiSuite 3
-> Install latest AURA
-> Install Live dash 1.01.07
