Results 1 to 10 of 20
01-13-2018 10:55 PM #1
Dan87 PC Specs Motherboard Asus ROG STRIX Z270H Processor Intel i7 7700k Memory (part number) Corsair Vengeance LED 3000mhz 2x8GB Graphics Card #1 MSI GTX 1080 Gaming X Sound Card Integrated SupremeFX Storage #1 Samsung SSD 850 EVO 250gb CPU Cooler Corsair H100i v2 Case Corsair 400C Power Supply Corsair RM750i
- Join Date
- Aug 2016
- Reputation
- 10
- Posts
- 30
AIO pump: where do you connect it?
Hi guys. I was wondering where did you connect your AIO pump. I have an h100i v2 and at the beginning I have connected it to the CPU header, then I switched to the pump header and I have connected an exhaust fan to the CPU header.
I have noticed that by switching to the pump header the AIO is extremely louder than it was when It was connected to the CPU header. I believe the reason is because now the pump constantly running at 100%. I was wondering if also the AIO fans are now running at 100% though which might be the reason why the AIO is so loud.
Any suggestion?
Thank you!
01-13-2018 11:09 PM #2
Gettinther PC Specs Motherboard ROG ZENITH EXTREME - Desktop Processor AMD Ryzen Threadripper 1950X 16 Cores, 32 Threads Memory (part number) Corsair Vengeance RGB 16GB 2x-(2 x 8GB) DDR4 3466 MHz Graphics Card #1 ROG STRIX-RX480-O8G-GAMING Sound Card ROG SupremeFX 8-Channel High Definition Audio CODEC S1220 Monitor SyncMaster 2253 bw & Polaroid TV - HDMI Storage #1 Corsair Force Series LE200 2.5" 480GB SATA 6Gb/s Solid State Drive Storage #2 Corsair Force Series LE200 2.5" 480GB SATA 6Gb/s Solid State Drive CPU Cooler Fractal Design Celsius S24 AIO Liquid Coolers 240MMr Case Coolermaster HAF 932 AMD Keyboard Redragon S101-3 Mouse Redragon S101-3 Headset/Speakers Creative Audigy 5.1 OS Windows 10 Pro 64bit
- Join Date
- Jan 2017
- Reputation
- 10
- Posts
- 6
Connections
Connect the pump power cable to the CPU_FAN header on your motherboard. • Connect the fans to the two connectors coming off the pump. this is from the manual on corsair web site - Link > http://www.corsair.com/en-us/hydro-s...uid-cpu-cooler
01-14-2018 12:08 AM #3
SherardG PC Specs Laptop (Model) ASUS ROG G752 & ASUS ROG G55VW Motherboard ASUS ROG Maximus X Hero Processor Intel® Core™ i7-8700K Memory (part number) 32 GB [G.Skill TZRGB] F4-3200C32Q-8GTZR x 4 Graphics Card #1 ROG-STRIX-GTX1080TI-O11G-GAMING Monitor ASUS ROG PG248Q Storage #1 Samsung 960 PRO MZ-V6P512 (512 GB) Storage #2 WD2003FZEX CPU Cooler NZXT Kraken X62 Case NZXT Noctis 450 ROG Power Supply Seasonic PRIME 80+ Ti 750 SSR-750TD Keyboard Logitech G413 Carbon Mouse Logitech G502 Proteus Spectrum Headset Razer Kraken Pro V2 Black Mouse Pad Logitech G440 OS Windows 10 10.0.16299 Network Router ASUS RT-AC88U
- Join Date
- Nov 2017
- Reputation
- 10
- Posts
- 101
For silence and to better control the pump+fans using your bundled software, connect to CPU_FAN then fans go to pump connection. If you want to control everything from BIOS (Using Q-FAN for example on AIS3) you can connect to AIO Pump, then your CPU fans through the CPU_FAN header directly. Please note that AIO pump header is high amp and will run your pumps at max speed all the time.
01-14-2018 11:06 AM #4
- Join Date
- Aug 2016
- Reputation
- 10
- Posts
- 30
Which solution would you advise? I have read that the pump deteriorate faster if it's not set at a constant speed. However, it is my understanding that the most recent ones won't experience this issue.
@Gettinthere: I have tried what the corsair manual suggested at the beginning, but the z270h motherboard has an AIO pump header so you have alternatives which is why I'm asking to share experiences. I'd like to understand what's the best setup. For sure I can tell you that the one advise by Corsair is the most quiet so far but I'm not sure if that's optimal. I am no expert and this is my first AIO, so I'm even seeking some advise on how to set the bios in case I decide to connect the AIO to the pump header instead of the CPU header.
01-14-2018 11:21 AM #5
Marcello.S PC Specs Motherboard Gigabyte Aorus Master Z390 Processor Intel Core i9-9900K Memory (part number) Kingston HyperX Savage 3000 CL15 2x8 GB Graphics Card #1 EVGA nVidia GTX 1080 Ti FTW3 Gaming Monitor ASUS VG248QE w/ nVidia 3D Vision 2 Storage #1 SAMSUNG SSD 840 PRO 256 GB + 512 GB Storage #2 Samsung nvme 970 Pro 512 GB CPU Cooler CORSAIR H115i PRO Case Cooler Master MasterCase MC500M Power Supply CORSAIR RM-750x w/ Premium PSU Cable Kit Keyboard Corsair K95 RGB Platinum Mouse Logitech G502 Proteus Spectrum Headset Corsair HS70 Mouse Pad ThunderX3 TMP30 Headset/Speakers Bose Sound Link Mini OS WINDOWS 10 PRO Accessory #1 APC Back-UPS 900
- Join Date
- Apr 2016
- Reputation
- 10
- Posts
- 119
I suggest you to read carefully the manual as you'll get all the info you need.
01-14-2018 12:30 PM #6
Menthol PC Specs Motherboard M 10 Apex / XI gene Processor 8700K / 9900K Memory (part number) 2x8 Gskill Trident Z 4266/2x2x8 Gskill Trident Z 4500 Graphics Card #1 RTX 2080ti / GTX 1060 Sound Card SoundBlaster Ae5 / Onboard Monitor BENQ 32" 4K Storage #1 Intel 900p 480GB/Samsung 960 Pro 1TB Storage #2 Intel 750 1.2TB/Plextor 1 TB 2X 950 Pro CPU Cooler Corsair H150i AIO / H1110i Case Corsair 740 ? Lian Li Air Power Supply Corsair AX 1200i / AX 1200i Keyboard Corsair Mouse ASUS Strix Headset HyperX Cloud Alpha Mouse Pad ASUS Headset/Speakers Logitech Z906 OS 10 X64 Pro Network Router Verizon Fios Accessory #1 Intel Wifi BT pcie card Accessory #2 Red Bull Accessory #3 English Breakfast Tea
- Join Date
- Jan 2012
- Reputation
- 241
- Posts
- 4,548
I recommend not using software to control your AIO, the following settings have worked for me without added software
Connect the pump power to to a SATA power connector, connect the pump control to the AIO header and let it run at 100% (the pump on 100% is very quit).
Connect the 2 radiator fans to CPU and CPU_opt fan headers on motherboard.
Control the fans in the bios, set to turbo if overclocking the CPU, silent for a more quit system, or standard
01-14-2018 12:31 PM #7
By default, thee aio header is configured to run at full speed. This is because some aio pumps don't spin-up at lower speeds. You can set the header to be controlled, though. The parameters and behaviour are the same as a normal fan header.
01-14-2018 01:41 PM #8
- Join Date
- Aug 2016
- Reputation
- 10
- Posts
- 30
01-14-2018 08:51 PM #9
- Join Date
- Aug 2016
- Reputation
- 10
- Posts
- 30
So, I wasn't able to connect both fans to the CPU headers as the bottom one couldn't reach it (I have the AIO in the front). However, I have connected the top one to the CPU_opt and the bottom one to the chassis. I was able to control the fans from the bios and set them to standard. I have noticed that my BIOS recognise doesn't recognise my rear fan even though it works just fine.
Do not hesitate to give me more advises if you have some, as previously mentioned I truly appreciated them. Thanks for your support!
01-14-2018 10:38 PM #10
MrAgapiGC PC Specs Motherboard Asus Maximus XI Code Processor 9900K Memory (part number) CMK32GX4M4B3600C18 Graphics Card #1 STRIX-GTX1080ti-O8G-GAMING Monitor AOC AGON AG2701QX (2) Storage #1 Samsung 960 EVO 256GB Storage #2 Kingston Savage 500GB CPU Cooler Nzxt X74 360mm AIO Case Nzxt H700 Power Supply EVGA 850 G2 Keyboard Logitech G810 Mouse Asus Spartha Headset Hyper X Cloud Revolver S Mouse Pad Hyper X Fury S 900mx420mm Headset/Speakers Logitech Z337 OS Windows 10 64btis Network Router TpLink Archer C9 Accessory #1 EKWB FANs all of them
- Join Date
- Nov 2011
- Reputation
- 27
- Posts
- 1,781
