Formula V Crosshair Z Random Power off
ShadowDarkblade
I've had my motherboard for a while now with minimal issues but since December I am unable to play any games when I try the PC shuts off no Blue screen of death no warning at all but if I run a system stability test (AIDA 64 Extreme Intel Burn Test and Prime95) and put the system under 100% load (GPU CPU and Ram) system doesn't shutdown. One thing I have noticed is that my H100i V2 will crank up the fans just before it crashes Though the temps on the CPU are fine.
CPU Temps under full load 70c
CPU Temps IDLE 25c - 30c
Things i have tried.
1. Removing all my ram and running with each stick individuality. (No Change)
2. Re-seating all my components (RAM GPU CPU) (No Change)
3. Updating Drivers (No Change)
4. Yelling at it to work and stop crashing :mad: (No Change)
PC Hardware:
OS: Windows 10 PRO 1709
MB: Formula V Crosshair Z (Latest Bios)
CPU: AMD FX 9590 (Yes I know its just a 8350 overclocked They were out of 8350's and gave me the 9590 for the price of the 8350)
GPU: AMD R9 290x Vaper-x 8GB
RAM: Corsair Vengeance Pro DDR3 2400MHZ 16GB
PSU: Rosewill PHOTON Series 1200W
SSD: Kingston V300 240GB
HDD: 2TB Seagate 7200RPM
0 REPLIES 0
