Results 1 to 7 of 7
    ROG Enthusiast Array
    Dec 2014
    45
    Press the Power button twice in Erp mode
    I noticed if I Erp S5 or S4 & S5 under APM configuration enabled I must press the power button twice to power the PC. The first time the PC powers for about a second and then turns off. The second time it will power up normally. I must add I have Windows Fast Startup off. When Fast Startup is enabled if you press a key on the keyboard the keyboard lights up and I don't like that.
    Has anybody noticed this behavior? On my last build with a Maximus 7 hero I didn't have this problem using S5. I like S5 because everything is powered off.
    If I turn off the power supply switch and then switch it back on I get the same results without the Erp enabled. The ErP S5 is the same as removing Power to the PC. Could somebody with a Maximus X Hero try turning the Power supply switch off and back on and see if the PC will boot with one press of the power button? With the Power Supply switch off press the power button and hold down to discharge MB then turn switch back on.
    I just found out that if I press the power button once and wait the PC powers up then down and then back up and boots normally.
    Dec 2017
    30
    Quote Originally Posted by wing_man View Post
    I built my system around Christmas. Asus formula X, I7 8700k, 1080ti.
    Exact same issue. With ErP enabled in S5, I press power: pc powers on, light flashes and fans spins for half a second, flicks off, then powers on as normal(I don't have to press power twice)
    ErP disabled this doesn't occur. Pc starts right away, but my USB microphone light continually shines lighting up my living room at night a cool blue.
    Here's a video showing exactly what happens with ErP enabled:
    https://youtu.be/Ndf6A9g2phU
    Tech Marketing Manager HQ Array Raja@ASUS's Avatar
    Apr 2011
    164
    7,453
    For the op, this may have something to do with the psu you are using. It's possible the rail isnt pulling up as required by the board.
    The rig starting twice with erp enabled is normal. Just the way power needs to be sequenced.
    ROG Guru: Yellow Belt Array Feklar PC Specs
    Feklar PC Specs
    MotherboardAsus Maximus XIII Apex
    Processori9 11900k
    Memory (part number)G.SKILL Trident Z Royal F4-3600C15D-16GTRS
    Graphics Card #1EVGA GeForce RTX 3090 Ti FTW3 ULTRA w/ Ek Waterblock
    MonitorLG38gl950g
    Storage #1Samsung 870 Evo 2TB
    Storage #2850 Evo 1TB and 2TB
    CPU CoolerCustom Water Cooling
    CasePhanteks Enthoo 719
    Power SupplyEVGA SuperNOVA 1000 T2
    Keyboard Logitech G513 Carbon
    Mouse Logitech G502 Hero
    Headset Audio Technica ath-msr7b
    Headset/Speakers Topping D30 Pro DAC and Topping A90 Headphone Amp
    OS Windows 10 Professional
    Accessory #1 Mo-Ra 3 Pro 4x180 Radiator
    Accessory #2 Koolance Fittings and QDC's
    Accessory #3 EK Magnitude CPU block w/EK Vector GPU block
    Feklar's Avatar
    May 2012
    11
    156
    Same thing here. My Rampage VI Apex does it, my Maximus X Hero does it. My Maximus X Apex and the Apex IX both did not have this anomaly. I am using the same psu for all of these boards. Disabling S5 cures the issue. I believe Elmor verified this on his board as well.
    i9 11900k + Asus Maximus XIII Apex + EVGA RTX 3090 Ti FTW3 ULTRA
    Trident Z Royal F4-3600C15D-16GTRS + Samsung 870 Pro SSD, EVO 1TB, EVO 2TB
    EVGA SuperNOVA 1000 T2 Power Supply + Phanteks Enthoo 719 case
    Ek Magnitude CPU block, Ek GPU block
    Koolance Fittings and QDC's + Mo-Ra 3 Pro 4x180 Radiator
    LG 38GL950G Monitor +
    Windows 10 Pro
    Apr 2011
    164
    7,453
    Quote Originally Posted by Feklar View Post
    Board models often utilize rail distribution according to the platform and the number/type of onboard devices, so it's not surprising to see different behaviour.
    Feklar PC Specs
    Processori9 11900k
    MonitorLG38gl950g
    Feklar's Avatar
    May 2012
    11
    156
    That makes sense. I only use s5 to turn off the onboard led's. I'm using the Hero X right now so I can leave s5 disabled since only the start button is illuminated when it's off. It would be convenient if there was an option in the bios to disable the onboard led's when the unit is powered off. Similar to the option with the aura led's.
    Windows 10 Pro
  7. #7
    Jan 2014
    26
    Same here maximus X hero, never had such "problem" with maximus vii hero.
    I thought it's just something to do with O/C, I guess not.
